Ubuntu 18.04.1, HPLIP 3.17.10.
I am trying to install HPLIP using Synaptic. The installation reports no errors. But, when I start the HP system tray, I get this error message:
File "/usr/bin/hp-toolbox", line 269, in <module>
QApplication, ui_package = utils.import_dialog(ui_toolkit)
TypeError: 'NoneType' object is not iterable
Also, the HP icon in the tray area does nothing if I click on it - although I am able to start the HPLIP Toolbox, and that seems to work.
When I run hp-check, it tells me that the following packages are missing/incompatible, and that I need to install them manually:
libnetsnmp-devel
snmp-mibs-downloader
libsnmp-dev
I do not know where to find the first two, nor how to install them manually.
Regarding libsnmp-dev: It is not installed, but via Synaptic versions 5.7.3+dfsg-1.8ubuntu3 and 5.7.3+dfsg-1.8ubuntu3.1 are available to install. However, when I try to install libsnmp-dev via Synaptic, it tells me that the following packages will be removed - but I don't want them to be removed (especially npm):
libssl1.0-dev
node-gyp
nodejs-dev
npm
How do I get the missing packages installed, get HPLIP working, get rid of the error message (above), and make the HP system tray to work, without uninstalling npm and those other packages?
Output of the apt-cache policy libssl1.0-dev node-gyp nodejs-dev npm:
libssl1.0-dev:
Installed: 1.0.2n-1ubuntu5.2
Candidate: 1.0.2n-1ubuntu5.2
Version table:
*** 1.0.2n-1ubuntu5.2 500
500 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
100 /var/lib/dpkg/status
1.0.2n-1ubuntu5 500
500 http://archive.ubuntu.com/ubuntu bionic/main amd64 Packages
node-gyp:
Installed: 3.6.2-1ubuntu1
Candidate: 3.6.2-1ubuntu1
Version table:
*** 3.6.2-1ubuntu1 500
500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
500 http://archive.ubuntu.com/ubuntu bionic/universe i386 Packages
nodejs-dev:
Installed: 8.10.0~dfsg-2ubuntu0.4
Candidate: 8.10.0~dfsg-2ubuntu0.4
Version table:
*** 8.10.0~dfsg-2ubuntu0.4 500
500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
8.10.0~dfsg-2ubuntu0.2 500
500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
8.10.0~dfsg-2 500
npm:
Installed: 3.5.2-0ubuntu4
Candidate: 3.5.2-0ubuntu4
Version table:
*** 3.5.2-0ubuntu4 500
Output of sudo apt install libsnmp-dev:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
gyp libjs-async libjs-inherits libjs-node-uuid libuv1-dev node-abbrev
node-ansi node-ansi-color-table node-archy node-async node-balanced-match
node-block-stream node-brace-expansion node-builtin-modules
node-combined-stream node-concat-map node-cookie-jar node-delayed-stream
node-forever-agent node-form-data node-fs.realpath node-fstream
node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs
node-hosted-git-info node-inflight node-inherits node-ini
node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile
node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream
node-node-uuid node-nopt node-normalize-package-data node-npmlog node-once
node-osenv node-path-is-absolute node-pseudomap node-qs node-read
node-read-package-json node-request node-retry node-rimraf node-semver
node-sha node-slide node-spdx-correct node-spdx-expression-parse
node-spdx-license-ids node-tar node-tunnel-agent node-underscore
node-validate-npm-package-license node-which node-yallist
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libpci-dev libsensors4-dev libssl-dev libssl-doc libudev-dev libwrap0-dev
The following packages will be REMOVED:
The following NEW packages will be installed:
libpci-dev libsensors4-dev libsnmp-dev libssl-dev libssl-doc libudev-dev
libwrap0-dev
0 upgraded, 7 newly installed, 4 to remove and 7 not upgraded.
Need to get 3,843 kB of archives.
After this operation, 1,932 kB of additional disk space will be used.
Do you want to continue? [Y/n]
