Scripting novice here.
I have created a script which can show you the ip address of the website which has been entered.
My script:
#! /bin/bash
echo "Enter web address : "
read address
echo "Entered web address : $address"
nslookup "$address"
Script in use:
Enter web address : google.com
Server:     127.0.1.1
Address:    127.0.1.1#53
Non-authoritative answer:
Address: 216.58.206.46
How would I then export that information into a text file?
Thanks
Jymes
  • 61
./someScript.sh > someFile.txt
Now enter address (e.g. google.com) and hit enter
Or more correct solution - edit script. For example:
#! /bin/bash
read address
nslookup "$address" > someLogFile.txt
UPD fr you:
The '>' sign here means redirection to file , so if you will type echo 666 > file.txt there will be created file.txt with 666 text inside.
