I have been having trouble installing the latest nvidia-410 driver to use with CUDA. I can install them directly from Nvidia's website but it means that the package manager doesn't recognize that the official drivers are installed. Attempts to install them via the terminal have failed as I get the following error. Obviously I have done something wrong somewhere but not sure what. Any help is appreciated.
nathan@BB-8:~$ sudo apt -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
nvidia-410
The following NEW packages will be installed
nvidia-410
0 to upgrade, 1 to newly install, 0 to remove and 307 not to upgrade.
2 not fully installed or removed.
Need to get 0 B/96.9 MB of archives.
After this operation, 394 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 179510 files and directories currently installed.)
Preparing to unpack .../nvidia-410_410.79-0ubuntu1_amd64.deb ...
Unpacking nvidia-410 (410.79-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-410_410.79-0ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-gnu/libGLX_indirect.so.0', which is also in package libglx-mesa0:amd64 18.0.5-0ubuntu0~18.04.1
Ninja Edit:
Worth adding this is the error I get with the manually installed Nvidia drivers
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies.
aptitude : Depends: aptitude-common (= 0.8.10-6ubuntu1) but it is not going to be installed
Depends: libcwidget3v5 but it is not going to be installed
Depends: libsigc++-2.0-0v5 (>= 2.8.0) but it is not going to be installed
libcuda1-410 : Depends: nvidia-410 (>= 410.79) but it is not going to be installed
nvidia-opencl-icd-410 : Depends: nvidia-410 (>= 410.79) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
