When I give sudo apt-get update and sudo apt install -f I am getting errors and stuck. Below are console logs for your reference.
Logs of sudo apt-get update command:
Ign:1 http://dl.google.com/linux/chrome/deb stable
InRelease
Hit:2 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu xenial
InRelease
Hit:3 http://package.perforce.com/apt/ubuntu trusty     InRelease
Hit:4 https://repo.skype.com/deb stable     InRelease
Hit:5 http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial
InRelease
Hit:6 http://linux.teamviewer.com/deb stable     InRelease
Hit:7 http://linux.teamviewer.com/deb preview     InRelease
Hit:8 http://dl.google.com/linux/chrome/deb stable Release
Hit:9 http://apt.postgresql.org/pub/repos/apt xenial-pgdg InRelease
Hit:10 http://ppa.launchpad.net/mc3man/xerus-media/ubuntu xenial
InRelease
Hit:12 https://download.sublimetext.com apt/stable/ InRelease
Hit:13 http://ppa.launchpad.net/team-gcc-arm-embedded/ppa/ubuntu
xenial InRelease
0% [Connecting to in.archive.ubuntu.com (2001:67c:1560:8001::14)]
[Connecting to archive.ubuntu.com (2001:67c:1360:8001::21)]
[Connecting to o
Here my console stuck after this line appeared on the terminal.
Logs of sudo apt install -f command:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  qml-module-qtquick-controls qml-module-qtquick-dialogs qml-module-qtquick-privatewidgets
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libpng12-0:i386
The following packages will be upgraded:
  libpng12-0:i386
1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
5 not fully installed or removed.
Need to get 0 B/122 kB of archives.
After this operation, 11.3 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: warning: files list file for package 'python-minimal' missing; assuming package has no files currently installed
(Reading database ... 321705 files and directories currently installed.)
Preparing to unpack .../libpng12-0_1.2.54-1ubuntu1.1_i386.deb ...
Unpacking libpng12-0:i386 (1.2.54-1ubuntu1.1) over (1.2.50-2+deb8u3) ...
dpkg: error processing archive /var/cache/apt/archives/libpng12-0_1.2.54-1ubuntu1.1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libpng12-0/ANNOUNCE', which is different from other instances of package libpng12-0:i386
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for libc-bin (2.23-0ubuntu10) ...
Please help me so that I can solve these errors.
Thanks
wjandrea
  • 14,504
Bhavin
