After installing according to How to install MFOC
I am currently using ubuntu on VM oracle
I connected ACR122U card reader and ran mfoc -O
The reader's indicator is lit so I think the reader is working fine
pcsc_scan is able to detect the reader and card
$ mfoc -O mycard.mfd
info    libnfc.config    Unable to open file: /etc/nfc/libnfc.conf
debug    libnfc.config    Unable to open directory: /etc/nfc/devices.d
unknown    libnfc.general    log_level is set to 3
debug    libnfc.general    allow_autoscan is set to true
debug    libnfc.general    allow_intrusive_scan is set to false
debug    libnfc.general    0 device(s) defined by user
No NFC device found.
I have the same issue that is solved for me by running sudo modprobe -r pn533_usb and sudo modprobe -r pn533 You can also check if you can reed the card with sudo nfc-list
