I have some python scripts saved in a sub-folder called "Documents/downloadFundamentals"
And I have the following bash script:
/home/john/.virtualenvs/investFundamentals/bin/python scrapStockList.py
/home/john/.virtualenvs/investFundamentals/bin/python downloadHistoricalData.py
/home/john/.virtualenvs/investFundamentals/bin/python updateHistoricalData.py
/home/john/.virtualenvs/investFundamentals/bin/python insertDocsToCollection.py
/home/john/.virtualenvs/investFundamentals/bin/python filterStocks.py
/home/john/.virtualenvs/investFundamentals/bin/python getCurrentPortfolio.py
/home/john/.virtualenvs/investFundamentals/bin/python accountSummary.py
The crontab task seems to be running, but no output.
Do I need to add the directory before each.py?
JOHN
  • 101
Short answer - yes, you have to make it either
/home/john/.virtualenvs/investFundamentals/bin/python /path/to/script/scrapStockList.py
or use #!/usr/bin/env python and make each file executable with chmod +x /path/to/scrapStockList.py. Use of virtualenv suggests you may be running Python version other than system default, so probably first option is more suitable for your case.
To quote related post by Gilles:
Cron's default path is implementation-dependent, so check your man page
When you call python script.py, the interpreter looks for script.py in current working directory. So your commands fail because Python interpreter in your question starts out in the working directory which is other than where your scripts are located.
