More than once I've had to go into apt to remove JDK > 8 because, at least for the moment, umake installs Netbeans 8 which only runs on JDK 8.
I only need JDK 8 for Netbeans, and that temporarily until umake install NB 9. That being said, how can I get the system to stay at JDK 8 (and maybe even JVM 8?) in concert with SDKMAN?
Or, fundamentally, are these different systems -- Java versioning specific to a user account for SDKMAN versus the system configuration?
thufir@dur:~$
thufir@dur:~$ javac -version
javac 11.0.1
thufir@dur:~$
thufir@dur:~$ sdk ls java
Available Java Versions
     12.ea.20-open
     11.0.1-zulu
     11.0.1-open
     10.0.2-zulu
     10.0.2-open
     9.0.7-zulu
     9.0.4-open
   * 8.0.192-zulu
     8.0.191-oracle
     7.0.201-zulu
     6.0.119-zulu
     1.0.0-rc-10-grl
     1.0.0-rc-9-grl
     1.0.0-rc-8-grl
+ - local version
* - installed
> - currently in use
thufir@dur:~$
Not sure what happened to JDK 8:
thufir@dur:~$
thufir@dur:~$ java -version
openjdk version "11.0.1" 2018-10-16
OpenJDK Runtime Environment (build 11.0.1+13-Ubuntu-2ubuntu1)
OpenJDK 64-Bit Server VM (build 11.0.1+13-Ubuntu-2ubuntu1, mixed mode, sharing)
thufir@dur:~$
fixed for now:
thufir@dur:~$
thufir@dur:~$ sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                            Priority   Status
  0            /usr/lib/jvm/java-11-openjdk-amd64/bin/java      1111      auto mode
  1            /usr/lib/jvm/java-11-openjdk-amd64/bin/java      1111      manual mode
* 2            /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java   1081      manual mode
Press <enter> to keep the current choice[*], or type selection number: 2
thufir@dur:~$
thufir@dur:~$ sudo update-alternatives --config javac
There are 2 choices for the alternative javac (providing /usr/bin/javac).
  0            /usr/lib/jvm/java-11-openjdk-amd64/bin/javac   1111      auto mode
  1            /usr/lib/jvm/java-11-openjdk-amd64/bin/javac   1111      manual mode
* 2            /usr/lib/jvm/java-8-openjdk-amd64/bin/javac    1081      manual mode
thufir@dur:~$
openjdk version "1.8.0_191"
OpenJDK Runtime Environment (build 1.8.0_191-8u191-b12-0ubuntu0.18.10.1-b12)
OpenJDK 64-Bit Server VM (build 25.191-b12, mixed mode)
thufir@dur:~$
javac 1.8.0_191
thufir@dur:~$
but it's getting repetitive.
Thufir
  • 4,631
