I'm trying to setup an openvpn client with Ubuntu 18. I run these magic steps:
$ sudo apt-get install openvpn
$ sudo apt-get install openvpn-systemd-resolved
$ sudo openvpn --client --config ./client.ovpn
Wed Jan 2 16:24:14 2019 OpenVPN 2.4.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep 5 2018
Wed Jan 2 16:24:14 2019 library versions: OpenSSL 1.1.0g 2 Nov 2017, LZO 2.08
<14>Jan 2 15:58:07 update-systemd-resolved: Link 'tun0' coming up
<14>Jan 2 15:58:07 update-systemd-resolved: Adding IPv4 DNS Server 172.17.0.1
<14>Jan 2 15:58:07 update-systemd-resolved: Setting DNS Domain mycompany.com
<14>Jan 2 15:58:07 update-systemd-resolved: Adding IPv4 DNS Server 8.8.8.8
<14>Jan 2 15:58:07 update-systemd-resolved: SetLinkDNS(4 3 2 4 172 17 0 1 2 4 172 17 0 1 2 4 8 8 8 8)
<14>Jan 2 15:58:07 update-systemd-resolved: SetLinkDomains(4 1 mycompany.com false)
Wed Jan 2 15:58:12 2019 ROUTE remote_host is NOT LOCAL
Wed Jan 2 15:58:12 2019 /sbin/ip route add 96.78.182.190/32 via 172.20.10.1
Wed Jan 2 15:58:12 2019 /sbin/ip route add 8.8.8.8/32 metric 101 via 172.27.232.1
Wed Jan 2 15:58:12 2019 /sbin/ip route add 172.27.224.0/20 metric 101 via 172.27.232.1
Wed Jan 2 15:58:12 2019 /sbin/ip route add 172.17.0.0/16 metric 101 via 172.27.232.1
Wed Jan 2 15:58:12 2019 Initialization Sequence Completed
where:
$ tail ./client.ovpn # Recently downloaded from the openvpn server
... # Appended this magic
.... # from here: https://askubuntu.com/questions/1032476/ubuntu-18-04-no-dns-resolution-when-connected-to-openvpn
script-security 2
dhcp-option DNS 172.17.0.1
dhcp-option DOMAIN mycompany.com
up /etc/openvpn/update-systemd-resolved
down /etc/openvpn/update-systemd-resolved
down-pre
And if I look at:
$ ls -la /etc/resolv.conf
lrwxrwxrwx 1 root root 39 Nov 21 16:53 /etc/resolv.conf -> ../run/systemd/resolve/stub-resolv.conf
$ cat /etc/resolv.conf
nameserver 127.0.0.53 <<< SHOULD BE 172.17.0.1
search mycompany.com
So it seems that the openvpn client didn't configure /etc/resolv.conf as happened with Ubuntu 14. Without this, if I "ping git" or "ping git.mycompany.com" to find our internal git service (or any internal service), I simply git the IP address of cable modem for all ping requests.
If I edit /etc/resolv.conf and replace 127.0.0.53 with 172.17.0.1 as was requested in client.ovpn, then all works fine.
Why doesn't this client.ovpn cause /etc/resolv.conf to be updated in Ubuntu 18?
Curiously, systemd-resolve disagrees with /etc/resolv.conf. What's up with that?
$ systemd-resolve --status
Global
DNSSEC NTA: 10.in-addr.arpa
16.172.in-addr.arpa
home
internal
intranet
lan
local
private
test
Link 4 (tun0)
Current Scopes: DNS
LLMNR setting: yes
MulticastDNS setting: no
DNSSEC setting: no
DNSSEC supported: no
DNS Servers: 172.17.0.1
8.8.8.8
DNS Domain: mycompany.com
Link 2 (wlp2s0)
Current Scopes: DNS
LLMNR setting: yes
DNSSEC setting: no
DNS Servers: 172.20.10.1
fe80::1c71:e8cb:d5ec:89ef
For dig, at least, whatever systemd-resolve --status is reporting, is ignored:
$ dig git
; <<>> DiG 9.11.3-1ubuntu1.3-Ubuntu <<>> git
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 55917
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;git. IN A
;; Query time: 0 msec
;; SERVER: 127.0.0.53#53(127.0.0.53) <<< Not the DNS I want
;; WHEN: Wed Jan 02 15:41:39 PST 2019
;; MSG SIZE rcvd: 32
Related questions that didn't help:
