14
While trying to upgrade Ubuntu from 16.04 to 18.04 I get the following output:
Connection to Snap Store failed
Your system does not have a connection to the Snap Store. For the best upgrade experience make sure that your system can connect to api.snapcraft.io. Do you still want to continue with the upgrade?
Continue [yN]
I would like to fix this before updating. I can find similar problems described online, but they all seem to be caused by snapcraft.io being temporarily down which is not the case right now according to status.snapcraft.io.
(edit: One of these similar problems is Problem with snap store which is mentioned in the comments below as a possible duplicate, but as that question contains very little info it is difficult to know whether the problem is the same and no answers are given that are helpful in my case.)
If I try to run
snap install hello
I get
net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
error: unable to contact snap store
There is nothing wrong with my internet connection. snap version gives me
snap 2.36.3
snapd 2.36.3
series 16
ubuntu 16.04
kernel 4.15.0-43-generic
Any ideas on what might be the problem and how to fix it?
Cadoiz
  • 278
AstridNeu
  • 141
For me it was a proxy problem:
I couldn't remember that I set those (its funny how many places there are to set proxies...), but anyway clearing the proxies solved my problem when I changed to an environment without a proxy:
sudo snap set system proxy.http=""
sudo snap set system proxy.https=""
Jan
  • 1,223
I also got the similar error while updating from 18.04.4 LTS to 20.04 LTS yesterday.
Following worked for me:
snap refresh snapd
systemctl restart snapd
Note: If you get the error snap snapd is not installed, then first install snapd and then try executing above mentioned commands.
Hope this helps.
Harshil
  • 161
