21
"sudo systemctl start hibernate.target" worked fine with 16.04 on a Acer B117 using legacy boot; Updating to 18.04 forced me to use UEFI and (Acer requirement) secure boot enabled. Suspend still works, but I need hibernate.
Swap partition is active and equals RAM size + 2GB;
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=myswapuuid"
journalctl -xe revealed failure to access /sys/power/disk
cat /sys/power/disk: [disabled]
cat /sys/power/state: freeze mem
Any suggestions?
Braiam
  • 69,112
olli61
  • 211
I have the same problem and, unfortunately, it's impossible with the official Ubuntu kernel since version 4.13 due to kernel lockdown patchset (efi-lockdown). Substantiation is:
There is currently no way to verify the resume image when returning from hibernate. This might compromise the signed modules trust model, so until we can work with signed hibernate images we disable it when the kernel is locked down.
Related Bionic commit you can see here.
This is a controversial decision and Linus declined to merge these changes to linux kernel.
A bit more details you can find is the article Kernel lockdown in 4.17? and its comments.
So while we wait some magic software, that will work with signed hibernate images, we can only use another kernel or disable secure boot.
Braiam
  • 69,112
Snaker
  • 507
I was able to hibernate using s2disk or pm-hibernate, but resume was failing. To fix this, as my system is booted up using UEFI instead of grub. I just had to reinstall the boot loader. To check if you are running UEFI use the following:
[ -d /sys/firmware/efi ] && echo "Installed in UEFI mode" || echo "Installed in Legacy mode"
if in UEFI mode, then I followed this guide to reinstall the bootloader, it varies if you are using an nvme disk or sata disk: https://support.system76.com/articles/bootloader/
The key is to run this command:
sudo update-initramfs -c -k all
make sure that in your kernalboot options you specify the partition or UUID of where to resume from, eg something like this:
resume=UUID=ed8347ed-2eb4-40bc-bc77-cc53b987ed88
You can add this by either:
  1. sudo kernel-stub -a "resume=UUID=..."
  2. edit the /etc/initramfs-tools/conf.d/resume file and add: resume=UUID=ed8347ed-2eb4-40bc-bc77-cc53b987ed88
check your /var/log/syslog file for something like this:
Aug  4 22:26:42 pop-os /usr/bin/kernelstub[19639]: kernelstub           : DEBUG    kopts: root=UUID=b37019a8-91f5-445f-94c1-7359a49ed5df ro quiet loglevel=0 systemd
.show_status=false resume=UUID=ed8347ed-2eb4-40bc-bc77-cc53b987ed88
If the resume is missing or wrong then you'll need to update your boot kernal again.
Braiam
  • 69,112
Lingster
  • 159
