I have 18.04 installed and I'm using it as jump box to reach other things.
Some of the things I need to access are only reachable via IPv6 and expect me to connect from a specific IPv6 address so my box has a static IPv6 address configured.
For some reason, I can't seem to prevent Ubuntu from generating and preferring privacy IPv6 addresses. This means that when I try to connect to other things, I appear to come from the wrong IPv6 address.
I've configured Netplan with a static IPv6 address (example address shown - I'm not really using that)
# This file describes the network interfaces available on your system
# For more information, see netplan(5).
network:
version: 2
renderer: networkd
ethernets:
ens192:
dhcp4: no
dhcp6: no
addresses: [192.168.212.152/25, '2001:0db8:85a3:0000::98/128']
gateway4: 192.168.212.129
nameservers:
search: ['mydomain.local']
addresses: [192.168.212.141, 192.168.212.142, '2001:0db8:85a3:0000::8d', '2001:0db8:85a3:0000::8e']
I have sysctl configured to not use IPv6 privacy addressing in /etc/sysctl.d/10-ipv6-privacy.conf:
# IPv6 Privacy Extensions (RFC 4941)
# IPv6 typically uses a device's MAC address when choosing an IPv6 address
# to use in autoconfiguration. Privacy extensions allow using a randomly
# generated IPv6 address, which increases privacy.
# Acceptable values:
# 0 - don’t use privacy extensions.
# 1 - generate privacy addresses
# 2 - prefer privacy addresses and use them over the normal addresses.
net.ipv6.conf.all.use_tempaddr = 0
net.ipv6.conf.default.use_tempaddr = 0
$ sysctl net.ipv6.conf.ens192.use_tempaddr
net.ipv6.conf.ens192.use_tempaddr = 0
I'm still getting a temporary IPv6 address:
$ ip -6 addr
2: ens192: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 2001:0db8:85a3:0000:20c:29ff:fede:fa42/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 2591895sec preferred_lft 604695sec
inet6 2001:0db8:85a3:0000::98/128 scope global
valid_lft forever preferred_lft forever
inet6 fe80::20c:29ff:fede:fa42/64 scope link
I can delete the privacy address or set it as deprecated but it re-appears whenever I netplan apply or reboot.
Am I doing something wrong or is this a bug?
