I have an issue with dpkg and install-info. I cannot add any new packages without encountering a couple errors:
   Setting up install-info (6.5.0.dfsg.1-2) ...
/usr/sbin/update-info-dir: 3: /etc/environment: source: not found
dpkg: error processing package install-info (--configure):
 installed install-info package post-installation script subprocess returned error exit status 127
 install-info
Clearly there is an issue with /etc/environment.
I have tried solutions from:
I have also reinstalled and purged/reinstalled install-info. I have checked the paths for /etc/environments and they conform to the first url above.
Any help appreciated & Thanks John
Kulfy
  • 18,154
After some further digging. The java on this system is messed up after having issues with Ubiquiti's controller after upgrade from 16.04 to 18.04. Removing java references from /etc/environment did the trick.
What my etc/environment looked like before:
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
JAVA_HOME="/usr/lib/jvm/java-8-oracle"
JAVA_HOME="/usr/lib/jvm/java-8-oracle" source /etc/environment
Fixed Version:
Reference: Upgrade Problems - Ubuntu Forums
Kulfy
  • 18,154
