When Snap updates a program it keeps the before versions installed. For example, I had Skype installed with the 60 version ( 567 MB ),but then it was updated with 63 version (606 MB) and finally the actual 66 version ( 607 MB ). As is the program uses 1.7 GB in the hard disc. If an user has in his system a few programs installed using Snap, probably it doesn't a big problem but if the idea is that in the future the most program is istalling as is, it will use a lot of space in the hard disc, and the process won't be efficient. If I uninstall Skype and re install again, it uses only 607 MB. If this issue is not known, how can I comunicate to Ubuntu programers to review it and try to improve the process ?
The developers were already discussing it long ago...and did something about it.
Your Ubuntu system, using snapd, will keep the current snap, plus two older snaps, for a total of three. Three is the default. You can reduce this to two using:
snap set system refresh.retain=N
N cannot be less than 2.
user535733
  • 68,493
