I've seen a few postings about migration with older Ubuntu versions.
What's the fastest way to migrate 120GB (80GB full) to a 1TB SSD under Ubuntu 18.04?
  • live duplicate or via image possible
  • how to extend the new volume on the new SSD?
Because I've only a limited time window once I've started I'd be happy for suggestions for the fastest way to get new system up and running again.
ssssstut
  • 939
What about using a Live System and
sudo dd if=/dev/sdx0 of=/dev/sdy0
and
sudo resize2fs /dev/sdy0
afterwards to resize the partition.
With sdx0 being your old partition and sdy0 being the new one.
user535733
  • 68,493
For a fast migration you have more than a couple of choice (and for fast not use dd, it copy bit per bit)
common used tools:
You can also decide to create a tar of your OS and restore it (more manual work to do but still fast then dd)
Personally I suggest you to use clonezilla, have a large community and a good Knowledge on the common issues can be encountered and of course because is opensource!
AtomiX84
  • 1,231
