I installed Ubuntu 16.04 on a Windows laptop, and as a result I have a hard disk with Windows File Format. Now I need to create a PostgreSQL cluster on that disk, because it is larger. However, I got a permission error:
yuqiong@yuqiong-G7-7588:/media/yuqiong/DATA$ sudo pg_createcluster -u yuqiong -d /media/yuqiong/DATA/postgresdb --start 11 3dcitydb
Creating new PostgreSQL cluster 11/3dcitydb ...
/usr/lib/postgresql/11/bin/initdb -D /media/yuqiong/DATA/postgresdb --auth-local peer --auth-host md5
The files belonging to this database system will be owned by user "yuqiong".
This user must also own the server process.
The database cluster will be initialized with locale "en_US.UTF-8".
The default database encoding has accordingly been set to "UTF8".
The default text search configuration will be set to "english".
Data page checksums are disabled.
fixing permissions on existing directory /media/yuqiong/DATA/postgresdb ... ok
creating subdirectories ... ok
selecting default max_connections ... 20
selecting default shared_buffers ... 400kB
selecting dynamic shared memory implementation ... posix
creating configuration files ... ok
running bootstrap script ... 2018-12-28 12:02:56.494 EST [405] FATAL: data directory "/media/yuqiong/DATA/postgresdb" has invalid permissions
2018-12-28 12:02:56.494 EST [405] DETAIL: Permissions should be u=rwx (0700) or u=rwx,g=rx (0750).
child process exited with exit code 1
initdb: removing contents of data directory "/media/yuqiong/DATA/postgresdb"
Error: initdb failed
However the user yuqiong indeed has rwx right on this drive:
yuqiong@yuqiong-G7-7588:/media/yuqiong/DATA$ ll | grep postgresdb
drwxrwxrwx 1 yuqiong yuqiong 48 Dec 28 12:02 postgresdb/
Presumably, I suspect this is because this disk is not actually a Linux File System format so the result returned by ll is not actually accurate.
In this case, how can I resolve this issue and grant the user yuqiong or postgres proper privilege on this drive? They need to be owners of directories to be able to create database cluster in PostgresQL.
Thanks!
