I am using Ubuntu 14.04 LTS i386. Currently installed linux-image-extra-3.13.0-153-generic.
From past few week I am dealing with this problem, but now the problem gets bigger...even I am not able to install any package from Ubuntu market/store. So far I have tried -f install to fix this and many commands like clean --purge autoremove remove dpkg.
result of sudo apt-get -f install
imtiyaz@Baka:~$ sudo apt-get -f install
[sudo] password for imtiyaz:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
linux-image-3.13.0-155-generic linux-image-3.13.0-161-generic
linux-image-3.13.0-162-generic linux-image-extra-3.13.0-155-generic
linux-image-extra-3.13.0-161-generic linux-image-extra-3.13.0-162-generic
linux-image-extra-3.13.0-163-generic
0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
21 not fully installed or removed.
After this operation, 562 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 486931 files and directories currently installed.)
Removing linux-image-extra-3.13.0-155-generic (3.13.0-155.205) ...
depmod: FATAL: could not load /boot/System.map-3.13.0-155-generic: No such file or directory
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-155-generic /boot/vmlinuz-3.13.0-155-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-155-generic /boot/vmlinuz-3.13.0-155-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-155-generic
grep: /boot/config-3.13.0-155-generic: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_bn5jf7/lib/modules/3.13.0-155-generic/modules.order: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_bn5jf7/lib/modules/3.13.0-155-generic/modules.builtin: No such file or directory
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-155-generic /boot/vmlinuz-3.13.0-155-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-155-generic /boot/vmlinuz-3.13.0-155-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-155-generic /boot/vmlinuz-3.13.0-155-generic
Generating grub configuration file ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Found linux image: /boot/vmlinuz-3.13.0-164-generic
Found initrd image: /boot/initrd.img-3.13.0-164-generic
Found linux image: /boot/vmlinuz-3.13.0-163-generic
Found initrd image: /boot/initrd.img-3.13.0-163-generic
Found linux image: /boot/vmlinuz-3.13.0-160-generic
Found initrd image: /boot/initrd.img-3.13.0-160-generic
Found linux image: /boot/vmlinuz-3.13.0-157-generic
Found initrd image: /boot/initrd.img-3.13.0-157-generic
Found linux image: /boot/vmlinuz-3.13.0-156-generic
Found initrd image: /boot/initrd.img-3.13.0-156-generic
Found linux image: /boot/vmlinuz-3.13.0-153-generic
Found initrd image: /boot/initrd.img-3.13.0-153-generic
Found linux image: /boot/vmlinuz-3.13.0-32-generic
Found initrd image: /boot/initrd.img-3.13.0-32-generic
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
usage: paste [-h]
paste: error: unrecognized arguments: -s -d
run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 2
dpkg: error processing package linux-image-extra-3.13.0-155-generic (--remove):
subprocess installed post-removal script returned error exit status 1
Removing linux-image-3.13.0-155-generic (3.13.0-155.205) ...
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-155-generic /boot/vmlinuz-3.13.0-155-generic
update-initramfs: Deleting /boot/initrd.img-3.13.0-155-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-155-generic /boot/vmlinuz-3.13.0-155-generic
usage: paste [-h]
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 2
Failed to process /etc/kernel/postrm.d at /var/lib/dpkg/info/linux-image-3.13.0-155-generic.postrm line 330.
dpkg: error processing package linux-image-3.13.0-155-generic (--remove):
Removing linux-image-extra-3.13.0-161-generic (3.13.0-161.211) ...
depmod: FATAL: could not load /boot/System.map-3.13.0-161-generic: No such file or directory
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-161-generic /boot/vmlinuz-3.13.0-161-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-161-generic /boot/vmlinuz-3.13.0-161-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-161-generic
grep: /boot/config-3.13.0-161-generic: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_JHFHuG/lib/modules/3.13.0-161-generic/modules.order: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_JHFHuG/lib/modules/3.13.0-161-generic/modules.builtin: No such file or directory
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-161-generic /boot/vmlinuz-3.13.0-161-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-161-generic /boot/vmlinuz-3.13.0-161-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-161-generic /boot/vmlinuz-3.13.0-161-generic
usage: paste [-h]
dpkg: error processing package linux-image-extra-3.13.0-161-generic (--remove):
Removing linux-image-3.13.0-161-generic (3.13.0-161.211) ...
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-161-generic /boot/vmlinuz-3.13.0-161-generic
update-initramfs: Deleting /boot/initrd.img-3.13.0-161-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-161-generic /boot/vmlinuz-3.13.0-161-generic
usage: paste [-h]
Failed to process /etc/kernel/postrm.d at /var/lib/dpkg/info/linux-image-3.13.0-161-generic.postrm line 330.
No apport report written because MaxReports is reached already
dpkg: error processing package linux-image-3.13.0-161-generic (--remove):
Removing linux-image-extra-3.13.0-162-generic (3.13.0-162.212) ...
depmod: FATAL: could not load /boot/System.map-3.13.0-162-generic: No such file or directory
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-162-generic /boot/vmlinuz-3.13.0-162-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-162-generic /boot/vmlinuz-3.13.0-162-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-162-generic
grep: /boot/config-3.13.0-162-generic: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_N9RaU9/lib/modules/3.13.0-162-generic/modules.order: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_N9RaU9/lib/modules/3.13.0-162-generic/modules.builtin: No such file or directory
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-162-generic /boot/vmlinuz-3.13.0-162-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-162-generic /boot/vmlinuz-3.13.0-162-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-162-generic /boot/vmlinuz-3.13.0-162-generic
usage: paste [-h]
dpkg: error processing package linux-image-extra-3.13.0-162-generic (--remove):
Removing linux-image-3.13.0-162-generic (3.13.0-162.212) ...
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-162-generic /boot/vmlinuz-3.13.0-162-generic
update-initramfs: Deleting /boot/initrd.img-3.13.0-162-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-162-generic /boot/vmlinuz-3.13.0-162-generic
usage: paste [-h]
Failed to process /etc/kernel/postrm.d at /var/lib/dpkg/info/linux-image-3.13.0-162-generic.postrm line 330.
dpkg: error processing package linux-image-3.13.0-162-generic (--remove):
Removing linux-image-extra-3.13.0-163-generic (3.13.0-163.213) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-163-generic /boot/vmlinuz-3.13.0-163-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-163-generic /boot/vmlinuz-3.13.0-163-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-163-generic
^[[1;2B^[[Arun-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-163-generic /boot/vmlinuz-3.13.0-163-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-163-generic /boot/vmlinuz-3.13.0-163-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-163-generic /boot/vmlinuz-3.13.0-163-generic
usage: paste [-h]
dpkg: error processing package linux-image-extra-3.13.0-163-generic (--remove):
imtiyaz@Baka:~$
output of df command:
imtiyaz@Baka:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 497644 4 497640 1% /dev
tmpfs 101544 1240 100304 2% /run
/dev/sda1 239212096 14561316 212476396 7% /
none 4 0 4 0% /sys/fs/cgroup
none 5120 0 5120 0% /run/lock
none 507712 16036 491676 4% /run/shm
none 102400 44 102356 1% /run/user
imtiyaz@Baka:~$
