I need to make an application in Vala, using Gtk, that supports keyboard accelerators that can be changed by the user.
First, I add an entry to the global Gtk.AccelMap and then set the accel_path for the Gtk.MenuItems. But, it doesn't work. The accels don't appear in the items of the menubar. To clear what I'm trying to do, here is a sample code:
// main.vala
public class MyWindow: Gtk.Window {
public MyWindow() {
this.set_default_size(500, 500);
var main_box = new Gtk.VBox(false, 0);
this.add(main_box);
// Menubar
var menubar = new Gtk.MenuBar();
main_box.pack_start(menubar, false, false, 0);
var file = new Gtk.MenuItem.with_label("File");
menubar.add(file);
var file_menu = new Gtk.Menu();
file.set_submenu(file_menu);
var quit_mi = new Gtk.MenuItem.with_label("Quit");
file_menu.append(quit_mi);
// Register a new accelerator with the global accelerator map
Gtk.AccelMap.add_entry("<MyWindow>/File/Quit", 'Q', Gdk.ModifierType.CONTROL_MASK);
quit_mi.set_accel_path("<MyWindow>/File/Quit");
// Connect signals
quit_mi.activate.connect(Gtk.main_quit);
// Label
var label = new Gtk.Label("My Window");
main_box.pack_start(label, true, true, 0);
this.destroy.connect(Gtk.main_quit);
int main(string[] args) {
Gtk.init(ref args);
var win = new MyWindow();
win.show_all();
Gtk.main();
return 0;
I use:
valac main.vala -o main --pkg gtk+-3.0
to compile the source code.
So, the question is: what's missing in the code? I think I need to do something else, but I don't know what.
