I was able to figure out how to do the reverse of this and go from a VirtualDisk to a hard disk (with the help of SuperUser, and the reverse of this should work.
First, DD your hard drive to a file while booted from a separate drive (say, booted in Live mode on your Ubuntu install disk). The file will be the size of the hard disk, but will be smaller later. For now, you need to create it onto a larger drive - sorry. (For instance, DD a 500GB hard disk onto an external hard disk with at least 500GB free). You could also try using GParted to shrink the partition with Ubuntu on it to around the max size you want your virtual drive to be.
For instance, the command would be sudo dd if=/dev/hda of=/media/ExternalHardDisk/rawimage.img or replace /dev/hda with /dev/hda1 for just the partition.This assumes that your hard disk is at /dev/hda (and the partition you want is /dev/hda1), which can be checked using the Disk Utility (palimpsest in the terminal) or in GParted while booted there, and that you mounted your external drive as /media/ExternalHardDisk/ (probably replace ExternalHardDisk.) DO NOT run these commands without first checking what drives are what on your currently booted system - they may change between when you are started in Ubuntu from your hard drive and when you start GParted or your Ubuntu live CD.
From here, our procedures may differ slightly. I use Sun (Oracle) VirtualBox, so I would use the VBoxManage command in the terminal to clone rawimage.img to a vdi image with VBoxManage convertfromraw /media/ExternalHardDisk/rawimage.img ~/virtualbox_image.vdi --format VDI. You could also try formatting to VMDK or VHD and changing the extension accordingly if any of these will work better for you. I can't help you from here, sadly, but VMWare should at least be able to import one of these or the raw image we created earlier. Or, "Just create a new virtual machine, and when the wizard gets to the step for hard drive(s), just say "use existing" instead of "create new", and point to the vmdk file you have."
