-1
MSI GF63 8Rd
ubuntu not shutdown
I tried several options on the command line and nothing
I tried to change the grub to: add modprobe.blacklist = nouveau after quiet splash and nothing
Help
I have an msi gf63 8rd, i7-8750H Hexa Core, Chipset: Intel, HM370 Graphics Card: IntelĀ® UHD Graphics 630 + NVIDIA GeForce GTX 1050 Ti 4GB GDDR5 Max-Q, I install UBUNTU or MINT and the pc does not power off. I installed ENDLESS OS and it works fine. The grub in both the ENDLESS OS, UBUNTU, and MINT is the same. The kernel in ENDLESS is 4.18.0.11 I updated the kernel in MINT to 4.18 and it still does not hang
dmesg errors:
[    0.000000] ACPI: Core revision 20170831
[    0.000000] ACPI Error: [\_SB_.PCI0.XHC_.RHUB.HS11] Namespace lookup failure, AE_NOT_FOUND (20170831/dswload-210)
[    0.000000] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170831/psobject-252)
[    0.000000] ACPI Exception: AE_NOT_FOUND, (SSDT:xh_cfhd4) while loading table (20170831/tbxfload-228)
[    0.000000] ACPI Error: 1 table load failures, 7 successful (20170831/tbxfload-246)
[    0.065542] ACPI: \: Used as boot ECDT EC to handle transactions
[    0.070711] ACPI Error: [_SB_.PCI0.RP05.PXSX] Namespace lookup failure, AE_NOT_FOUND (20170831/dswload2-191)
[    0.070722] No Local Variables are initialized for Method [PXSX]
[    0.070723] No Arguments are initialized for method [PXSX]
[    0.070725] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170831/psobject-252)
[    0.070730] ACPI Error: Method parse/execution failed \_SB.PCI0.RP04.PXSX, AE_NOT_FOUND (20170831/psparse-550)
[    0.072545] ACPI Error: [_SB_.PCI0.RP09.PXSX] Namespace lookup failure, AE_NOT_FOUND (20170831/dswload2-191)
[    0.072553] No Local Variables are initialized for Method [PXSX]
[    0.072554] No Arguments are initialized for method [PXSX]
[    0.072556] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170831/psobject-252)
[    0.072560] ACPI Error: Method parse/execution failed \_SB.PCI0.RP08.PXSX, AE_NOT_FOUND (20170831/psparse-550)
[    0.074393] ACPI Error: [_SB_.PCI0.RP13.PXSX] Namespace lookup failure, AE_NOT_FOUND (20170831/dswload2-191)
[    0.074400] No Local Variables are initialized for Method [PXSX]
[    0.074402] No Arguments are initialized for method [PXSX]
[    0.074403] ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170831/psobject-252)
[    0.074407] ACPI Error: Method parse/execution failed \_SB.PCI0.RP12.PXSX, AE_NOT_FOUND (20170831/psparse-550)
[    8.254890] dpc 0000:00:1d.0:pcie010: DPC error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    8.254911] dpc 0000:00:1d.4:pcie010: DPC error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    8.254966] efifb: probing for efifb
[   10.334776] sd 5:0:0:0: [sdb] No Caching mode page found
[   10.334830] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[   17.758015] tpm tpm0: A TPM error (378) occurred get tpm pcr allocation
[   18.218944] cannonlake-pinctrl INT3450:00: pin 16 cannot be used as IRQ
[   18.218947] genirq: Setting trigger mode 8 for irq 137 failed (intel_gpio_irq_type+0x0/0x140)
[   18.218978] i2c_hid i2c-CUST0001:00: i2c-CUST0001:00 supply vdd not found, using dummy regulator
[   18.219815] cannonlake-pinctrl INT3450:00: pin 16 cannot be used as IRQ
[   18.219817] genirq: Setting trigger mode 8 for irq 137 failed (intel_gpio_irq_type+0x0/0x140)
[   18.219824] i2c_hid i2c-CUST0001:00: Could not register for CUST0001:00 interrupt, irq = 137, ret = -1
[   18.219845] i2c_hid: probe of i2c-CUST0001:00 failed with error -1
[   18.220428] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[   22.942323] nouveau 0000:01:00.0: secboot: VPR scrubber binary failed!
[   22.942334] nouveau 0000:01:00.0: gr: init failed, -22
PerlDuck
  • 13,885
You're on the right track. Not beeing able to shut down is often an acpi or a graphics card problem. Since you blacklisted nouveau I assume you have a Nvidia GC. The devices are to be blacklisted in
/etc/modprobe.d/somefile.conf
"somefile.conf" can be any given name. More information about blacklisting is here :How to blacklist kernel modules? Using
lsmod
will show you the loaded kernel modules that you might try to blacklist.
dmesg
might tell you why the poweroff does not work.
kanehekili
  • 7,426
