xfce4: sudo startxfce4 - all good, but only startxfce4 - fail. Why?
How to correct this behavior? I think that need to change permissions, but where?
Thank for your attention to this problem, and thank for your opinions about it.
Ok as they said on thread suggested this is a duplicate of... try installing xfce-desktop and then try to start your environment. Also check if there's a xinitrc file under $HOME/.config/xfce4/xinitrc since that is configuration file that startxfce4 script reads from when run.
If it's absent or empty, check /etc/xdg/xfce4/xinitrc since that configuration file is run when you do sudo startxfce4. What you can do and is suggested by startxfce4 man page is to copy contents of xinitrc from /etc into the one that's in your home directory.
cat /etc/xdg/xfce3/xinitrc > $HOME/.config/xfce4/xinitrc
Then try to start your xfce DE. Hope it helps.
