-1
If you measure times in Ubuntu 18.04, the result apears in a single line:
$ time sleep 1
sleep 1  0.00s user 0.00s system 0% cpu 1.003 total
This doesn’t align with the POSIX standard, as described in time’s man page:
-p, --portability
       Use the following format string, for conformance with POSIX standard 1003.2:
                 real %e
                 user %U
                 sys %S
Now my question is:
Why does Ubuntu use its own format for displaying resource usage?
Also, how do I change the behavior? Using the -p option from the manual I cited above, I only get the following error:
$ time -p sleep 1
zsh: command not found: -p
-p sleep 1  0.00s user 0.00s system 73% cpu 0.002 total
pvorb
  • 101
Your error is a huge clue -
You are using zsh not BASH or DASH.
The man page for time pertains to the external /usr/bin/time program: bash as well as zsh provides its own time shell builtin (which happens to have an equivalent -p switch)
correcting comment by @steeldriver
I get a different result on my standard Ubuntu using the default bash - or what you no doubt want/expect.
guiverc@d960-ubu2:~$  time -p sleep 1
real 1.09
user 0.00
sys 0.00
guiverc
  • 33,561
