fsck from util-linux 2.31.1
/dev/sda6 contains a file system with errors, check forced.
/dev/sda6: Inodes that were part of a corrupted orphan linked list found.
/dev/sda6: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
        (i.e., without -a or -p options)
fsck exited with status code 4
The root filesystem on /dev/sda6 requires a manual fsck
Busybox v1.27.2(Ubuntu 1:1.27.2-2ubuntu3) built in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs) _
I installed Ubuntu 18.04. I earlier faced this problem which I solved by simply writing fsck /dev/sdax. Later on I faced unable to mount boot with something error (0,0), so I reinstalled Ubuntu again, but unluckily I updated and again I ended up with this.
This time when I run fsck /dev/sda7 it shows
fsck: error2 (no such file or directory) while executing fsck.ext2 for /dev/sda7
How to fix this? Please help
ARMAN
At the initfamfs prompt, type fsck -fy /dev/sda6.
You may also have a bad /boot/initrd.img* file if problems continue.
If you dual-boot with Windows, and have a Windows driver that reads/write to Linux ext2/3/4 partitions, remove it asap, as it's corrupting your Ubuntu.
heynnema
  • 73,649
