I installed mendeley desktop via this link. It installed properly and works fine when I open it from the gui menu.
However, I can't run it from terminal:
kp@kk:~$ mendeleydesktop
mendeleydesktop: command not found
kp@kk:~$
I located the software
kp@kk:~$ locate mendeleydesktop |grep /home
/home/kp/.local/share/mendeleydesktop
/home/kp/.local/share/applications/mendeleydesktop.desktop
The first item above seems like a link to a different directory, but I'm confused because I can't actually locate this file.
kp@kk:~/.local/share$ ls -al mendeleydesktop
lrwxrwxrwx 1 kp kp 30 Nov 19 17:38 mendeleydesktop -> /app/extra/bin/mendeleydesktop
The second item is just a file:
kp@kk:~/.local/share/applications$ cat mendeleydesktop.desktop
[Desktop Entry]
Name=Mendeley Desktop
GenericName=Research Paper Manager
Comment=Mendeley Desktop is software for managing and sharing research papers
Exec=/home/kp/.local/share/mendeleydesktop %f
Icon=mendeleydesktop
Terminal=false
Type=Application
Categories=Education;Literature;Qt;
X-SuSE-translate=false
MimeType=x-scheme-handler/mendeley;application/pdf;text/x-bibtex;
X-Mendeley-Version=1
Any idea where I can find the executable? I just want to be able to type mendeleydesktop and get mendeley to open. This is the only piece of my workflow I can't control from the terminal. I assume if I find the right object I can just make a link in my bashrc file.
You have provided mendeleydesktop.desktop file, where it says that your executable is
%f is a parameter and stands for file (look here https://specifications.freedesktop.org/desktop-entry-spec/desktop-entry-spec-latest.html#exec-variables). So typing
should work for you.
For me typing just
mendeleydesktop
works as it executes /usr/bin/mendeleydesktop, and /usr/bin is in PATH. I believe it should be in your path, too. Try to type
If that does not work, check, which files are installed with mendeleydesktop package. Type
dpkg -L mendeleydesktop
You will see all files that are installed, and find the one that is executed.
Kulfy
  • 18,154
nobody
  • 4,412
I think your issue is not about .desktop file, i also have
$ cat /home/praz/.local/share/applications/mendeleydesktop.desktop
[Desktop Entry]
Exec=/home/praz/.local/share/mendeleydesktop %f
Terminal=false
Type=Application
The problem's :
You need to switch from the standard text mode (tty) XWindows session to the default GNOME session (GDM)
try switch the gdm using CTRL+ALT+F2 to go back to GUI, or use a command chvt 1
after you switch back to GNOME, please check again the mendeley package using :
sudo apt-cache policy mendeleydesktop
and the output should be like :
$ sudo apt-cache policy mendeleydesktop
[sudo] password for praz:
mendeleydesktop:
  Installed: 1.19.3
  Candidate: 1.19.3
  Version table:
 *** 1.19.3 500
        500 https://desktop-download.mendeley.com/download/apt stable/main amd64 Packages
        100 /var/lib/dpkg/status
IF you still don't have the mendeley Repository, try to run :
sudo dpkg-reconfigure mendeleydesktop
for reconfigure mendeley package to include the mendeley repository and data directory of mendeley package, and check your mendeley package with type :
sudo dpkg -L mendeleydesktop
/usr/bin
/opt
/opt/mendeleydesktop
/opt/mendeleydesktop/lib
/opt/mendeleydesktop/lib/cpp
/opt/mendeleydesktop/lib/cpp/libstdc++.so.6
/opt/mendeleydesktop/lib/qt
/opt/mendeleydesktop/lib/qt/libQt5Widgets.so.5
/opt/mendeleydesktop/lib/qt/libicudata.so.56
Hope this helps.
