I have HP laptop with an external wifi Adapter as there is no Wifi adapter inbuild.
This is my ifconfig result
docker0   Link encap:Ethernet  HWaddr 02:42:fc:cf:ad:7c
          inet addr:172.17.0.1  Bcast:172.17.255.255  Mask:255.255.0.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eno1      Link encap:Ethernet  HWaddr 10:e7:c6:7c:81:c3
          collisions:0 txqueuelen:1000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:6880 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6880 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:580042 (580.0 KB)  TX bytes:580042 (580.0 KB)
virbr0    Link encap:Ethernet  HWaddr 00:00:00:00:00:00
          inet addr:192.168.122.1  Bcast:192.168.122.255  Mask:255.255.255.0
wlx502b73e86298 Link encap:Ethernet  HWaddr 50:2b:73:e8:62:98
          inet addr:192.168.43.254  Bcast:192.168.43.255  Mask:255.255.255.0
          inet6 addr: fe80::a85:c587:3653:359/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:53032 errors:0 dropped:0 overruns:0 frame:0
          TX packets:45991 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:42520401 (42.5 MB)  TX bytes:6912557 (6.9 MB)
I take my IP is 192.168.43.254 and wifi adapter is wlx502b73e86298
Now when I connect to another WIFI, my IP changes to
192.168.0.106
Can I keep some static IP lets say 192.168.0.10 and no matter whichever WIFI I am connected it should work fine?
I have tried following configuration in
 sudo nano /etc/network/interfaces
auto wlx502b73e86298
iface wlx502b73e86298 inet static
    address 192.168.0.10
    netmask 255.255.255.0
    gateway 192.168.0.1
dns-nameservers 8.8.4.4 8.8.8.8
And than run these commands
sudo ip addr flush wlx502b73e86298
 sudo systemctl restart networking.service
Now if I do ifconfig I can see my IP as 192.168.0.10
but ping google.com doesn't work and I cant access the internet.
Why I need a static IP is because I have a few containers running in Docker and all are pointing to Host IP. If Host IP changes I have to change IP in each container.
Use your localhost? 127.0.0.1.
You will need to bind your docker containers to localhost using something like "docker run -d -p 127.0.0.1:80:5000 base/theApp python theApp.py".
If this isn't an option you can use, you got two options.
The best solution is to bind your mac-address to your ip in all the dhcp-servers.
If you don't have access to the dhcp-server config you need to use a dhcp (dynamic setup) and an sub-interface with a static ip. Just remember to validate this with your network owner, otherwise it can cause network duplicate address errors. There is already a thread on this here askubuntu.com
Just add interface:[interface no] to add another interface configuration.
Example:
auto lo eth0 eth0:0 iface lo inet loopback
iface eth0 inet dhcp
iface eth0:0 inet static address ... netmask ...
