Sometimes, after I run some commands (for example git commands), I discover that I forgot some configurations or forgot to put some requirements... . So I thought about displaying a message, to remind me or warn me, (like the one displayed when we run sudo apt upgrade:
The following packages will be upgraded ... Do you want to continue [Y/n]?)
I want to get a similar message when I run a specific command ("Did you check the conf files, did you update the requirements file?) When I type Y, the command run and when I type n, the command stops.
How to do this in Ubuntu?
singrium
  • 7,320
Typically, when there are things that have to be done before an actual command runs - such as providing and setting up environment variables, adding extra positional parameters, etc - the command is placed into a wrapper script. How it should be implemented - that depends on the specific command you want and things you want to check before actual command runs. In the very simple case such as git, you could do something along the following lines:
#!/bin/sh
printf "%s\n" "Did you check the conf files, did you update the requirements file?[y/n]"
read answer
case "$answer" in
    [Yy])  exec git commit -a ;;
    [Nn]) printf "%s\n" "Please check. Exiting"; exit 1 ;;
esac
Of course the next question is the naming of the command. This script could be named git-commit or something similar. I would advice against naming wrapper scripts same as the original application.
See also:
