I've seen most of the forum answers to this issue, but all the fixes assume you can boot in Windows 10. Due to a Lenovo issue, i cannot boot my windows 10 OS, and in ubuntu i cannot recover the files because of the hybernation/fast startup issue.
What can i do?
EDIT: I have to say that the lenovo issue is: Error 1962. Which appear to be a common lenovo problem that most of the time is solved this way: https://howtoremove.guide/error-1962-lenovo-no-operating-system-found-fix/ Unfortunately, the fix did not work, and after contacting Lenovo support and ensuring disk storage functions with the BIOS, the only fix they could asses was reinstalling w10 with the Lenovo Recovery Download which re-installs and validates the W10 copy, but in the process deletes all the data. Which is the one thing we are trying to save.
EDIT 2 - THE FIX: Thanks for the comments and support, sadly none of the responses really answered the issue. Fortunately, the way to fix this is just to disconect the SATA HDD for the logical release, pluggin it back in, and do the usual linux files recovery. Then installing any OS you want.
gurlak7
In order of preference...
  1. repair the "Lenovo" problem that won't let you boot Windows, then boot Windows, then fully shutdown Windows
  2. boot a Windows Repair disc and run chkdsk (or repair) on the hard drive
  3. (and I hate to recommend this...) use sudo ntfsfix /dev/sdxx. See man ntfsfix for more information about this command.
heynnema
  • 73,649
THE FIX: Thanks for the comments and support, sadly none of the responses really answered the issue. Fortunately, the way to fix this is just to disconect the SATA HDD for the logical release, pluggin it back in, and do the usual linux files recovery. Then installing any OS you want. Dealing with the error 1962 should be addressed by using the LENOVO DATA RECOVERY TOOL
gurlak7
