I just upgraded to 18.04. Unfortunately during the update my laptop got stuck and restarted. After the restart everything seemed to work. A gig of updates later I got stuck on this problem. Apt dist-upgrade threw an error because of unmet dependencies and now I get the following Output when trying to fix it with apt --fix-broken install
sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libkf5calendarcore5 libkf5libkdepim5abi1 libkf5pimcommon5abi2
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libkf5akonadicalendar5abi2 libkf5alarmcalendar-data
libkf5alarmcalendar5abi1 libkf5mailtransport-data
libkf5mailtransport5abi2
The following packages will be REMOVED:
kio-smtp libkf5alarmcalendar5
The following NEW packages will be installed:
libkf5akonadicalendar5abi2 libkf5alarmcalendar5abi1
The following packages will be upgraded:
libkf5alarmcalendar-data libkf5mailtransport-data
2 upgraded, 3 newly installed, 2 to remove and 10 not upgraded.
41 not fully installed or removed.
Need to get 0 B/584 kB of archives.
After this operation, 743 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 278631 files and directories currently installed.)
Preparing to unpack .../libkf5mailtransport-data_17.12.3-0ubuntu4_all.deb ...
Unpacking libkf5mailtransport-data (17.12.3-0ubuntu4) over (17.04.3-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/libkf5mailtransport-data_17.12.3-0ubuntu4_all.deb (--unpack):
trying to overwrite '/etc/xdg/kmailtransport.categories', which is also in package kio-smtp 17.04.3-0ubuntu1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Here is also the output of apt upgrade for completeness sake:
sudo apt upgrade
You might want to run 'apt --fix-broken install' to correct these.
kde-config-mailtransport : Depends: libkf5mailtransport-data (= 17.12.3-0ubuntu4) but 17.04.3-0ubuntu1 is installed
Depends: libkf5mailtransport5abi2 (>= 17.07.70+git20170701) but it is not installed
kdepim-runtime : Depends: libkf5akonadicalendar5abi2 (>= 4:17.07.70+git20170920.1507) but it is not installed
Depends: libkf5alarmcalendar5abi1 (>= 4:17.11.70+git20170926.0843) but it is not installed
libkf5alarmcalendar5 : Depends: libkf5akonadicore5 (>= 4:15.12.0) but it is not installable
libkf5mailtransportakonadi5 : Depends: libkf5mailtransport-data (= 17.12.3-0ubuntu4) but 17.04.3-0ubuntu1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
As I said this output was my main reason to even try apt --fix-broken install
As it turns out I just needed to remove kio-smtp package for this to work again. Since normal apt operations wouldn't work because of the unmet dependencies I did it with:
sudo dpkg -r --force-depends kio-smtp
to circumvent the dependency checks.
