12
Every couple of days I get these errors that lockup the server.
[501.882940] print_req_error: I/O error, dev fd0, sector 0
[504.338961] print_req_error: I/O error, dev fd0, sector 0
[504.738984] print_req_error: I/O error, dev fd0, sector 0
[509.250929] print_req_error: I/O error, dev fd0, sector 0
[509.898921] print_req_error: I/O error, dev fd0, sector 0
[510.334916] print_req_error: I/O error, dev fd0, sector 0
[517.714867] print_req_error: I/O error, dev fd0, sector 0
[520.118801] print_req_error: I/O error, dev fd0, sector 0
[520.618864] print_req_error: I/O error, dev fd0, sector 0
[521.047029] print_req_error: I/O error, dev fd0, sector 0
I've blacklisted the floppy drive and I also disabled the floppy drive in vSphere. Any help would be appreciated! Thanks
waltinator
  • 37,856
John De La Motte
  • 131
6 Answers6
10
If you have removed your swap file then ensure that in step 3 that you have commented out the swap file line (it will have 'swap' in the same line) and in step 4 comment out the first (and only)
  1. Run this dpkg-reconfigure initramfs-tools and then restart and continue
  2. lsblk -f command, and note the UUID's
  3. Ensure that the UUID's in this file are right /etc/fstab -- sudo nano /etc/fstab
  4. Ensure that the UUID's in this file are also right /etc/initramfs-tools/conf.d/resume. -- sudo nano /etc/initramfs-tools/conf.d/resume.
  5. Run sudo update-initramfs -u and restart
Sources:
https://tinycp.com/community/show/solved-print-req-error-i-o-error-dev-fd0-sector-0,43.html#sidebar
https://lists.debian.org/debian-user/2017/09/msg00866.html
I saw this on the following website: https://tinycp.com/community/show/solved-print-req-error-i-o-error-dev-fd0-sector-0,43.html
# rmmod floppy
# echo "blacklist floppy" | tee /etc/modprobe.d/blacklist-floppy.conf
# dpkg-reconfigure initramfs-tools
For me this seems to work pretty fine! (Oh, I just saw the page was referenced already in an earlier anwer. But this containts step-by-step commands (as does the linked page) which solved the issue for me.)
Thanks
TomS
  • 161
Why are you disabling the Floppy Drive? Why not just remove it from the VM's configuration?
I completely removed the Floppy Drive from the configuration of the VM. Time will tell if the error returns.
PapaJim
This did not work on our 18.04 server, using tee gave permission denied to create the file. This however worked:
sudo rmmod floppy
sudo sh -c "echo 'blacklist floppy' >  /etc/modprobe.d/blacklist-floppy.conf"
sudo dpkg-reconfigure initramfs-tools
I kept getting this error, which made me boot into emergency mode and did not allow SSH/remote access.
I removed all custom /etc/fstab entries except the default ones. In my case I had entries to mount hard disks that were no longer plugged in, once I removed them I stopped getting that error. For reference, my error said the problem was with sr0, but I couldn't find a reference to sr0 in any logs/fdisk.
You can see my answer here: I encountered the print_req_error while trying to open Ubuntu 16.04 on my dual booted HP laptop
As I used to encounter the same problem.
