I just recently installed Ubuntu 18.10. After successful installation, I rebooted my system but Ubuntu didn't boot, it gets stuck at showing started GNOME display manager.
My keyboard is also not working. What is the problem? How can I get a complete Ubuntu desktop ready without any errors?
Zanna
  • 72,312
You may have a problem with an older computer, with an older GPU. Try this...
  • boot to recovery mode
  • choose root access
type:
sudo mount -o remount,rw /      # to remount the disk r/w
sudo pico /etc/gdm3/custom.conf # edit this file
change:
#WaylandEnable=false
to:
WaylandEnable=false
Then reboot.
heynnema
  • 73,649
I had the same problem with a new install of 19.04 on a Windows Hyper-V VM.
I was able to press Alt-F2 to get to the secondary TTY terminal and login and edit this file. Rebooted, and now have access to the GUI-desktop.
Zanna
  • 72,312
In my case (Ubuntu 23.10), I had accidentally auto-removed packages related to the Ubuntu Desktop, XDG, etc. I found those following this answer:
grep " remove " /var/log/apt/history.log
  1. Press Alt-F2 to get access to a terminal (or reboot and get into the Ubuntu recovery mode).
  2. Check for any packages you recently removed.
  3. Install such packages again: sudo apt install ubuntu-session, etc.
MakisH
  • 1,120
