I'm still very much a novice when it comes to Linux as a whole, and I have no clue what's happening here.
I tried to install redis-server in order to integrate BLAST into my JBrowse install (program to search for nucleotide sequences, and a visual browser for displaying this data). When I used:
sudo apt-get install redis-server
The install hangs at
Setting up redis-server (2:3.0.6-1ubuntu0.3) ...
after giving the program 2 days to run, I killed the thread by first using
ps aux | grep apt
Which gives
perryg    7954  0.0  0.0  14224   924 pts/7    S+   01:57   0:00 grep --color=au        to apt
root     38576  0.0  0.0  54792  3900 pts/3    S+   Dec14   0:00 sudo apt-get pu        rge --auto-remove redis-server
root     38577  0.0  0.0 118568 80428 pts/3    S+   Dec14   1:29 apt-get purge -        -auto-remove redis-server
I used
sudo kill 38577
sudo rm /var/lib/dpkg/lock
sudo dpkg --configure -a
sudo apt-get update
sudo apt-get autoremove
-or-
sudo apt-get install --fix-missing
and it always hangs at
Any help is appreciated.
Kulfy
  • 18,154
My solution was to kill all redis-server processes, and try the remove again.
ps aux | grep redis
And use kill <pid> or kill -9 <pid>.
I had the same issue and it turns out I already had an Redis installed (not from apt) and running by default. I removed the init script for the non-packaged redis:
$ sudo mv /etc/init.d/redis_#### /usr/local/src/redis-stable/
Then when I restarted I could successfully install/remove the redis-server package.
Looks like it's a bug : https://github.com/antirez/redis/issues/3241
So the (temporary) solution is to edit /etc/redis/redis.conf and remove the '::1' in the line:
bind 127.0.0.1 ::1
After that, you can start redis with systemctl or service.
xtof54
  • 101
