I just setup ubuntu 11.10 on Dell XPS 15z by following the instruction from here:
Current status/known issues for DELL XPS 15z?
Everything seems ok until the point I failed to run openGL on chrome: http://get.webgl.org
This is the step I follow to setup the machine:
1) Add bumblebee ppa
2) install nvida-current from restricted drivers
3) install bumblebee (remember to "sudo usermod -a -G bumblebee YOURUSERNAME" as said by the bumblebee readme)
4) install mesa-utils
5) reboot
6) try intel card with terminal command "glxspheres"
7) try nvidia card with terminal command "optirun glxspheres"
While the step 7 is success, but step 6 was failed with following error message:
Xlib: extension "GLX" missing on display ":0".
When I run "glxinfo|grep OpenGL", it prompts
"Xlib: extension "GLX" missing on display ":0"."
This is my /etc/X11/xorg.conf
Section "Device"
    Identifier      "Default Device"
    Option  "NoLogo"        "True"
EndSection
I have turned on webgl support for chrome as well.
Fairly new to this, how could I fixed this?
TonyMocha
  • 389
As the title does not mention NVidia, (and for those who can run WebGL on Firefox but can't on Chrome) another option is to try enable Override rendering software list in
chrome://flags
Hope it helps
Omegafil
  • 266
Successfully have it running with both intel and nvidia graphics running by following instruction from here:
Did a test on glxinfo | grep OpenGL and optirun | grep OpenGL, both working.
Eventually the webgl issue for chrome is by misconfiguring the chrome://flags, reset it and everything is fine.
TonyMocha
  • 389
I had a very similar problem. Try starting Chrome with this command google-chrome --ignore-gpu-blacklist. Home this helps.
Altkey
  • 27
I had the same issue. After installing Bumblebee drivers is used:
    optirun /opt/google/chrome/google-chrome --ignore-gpu-blacklist %U
It works like a charm!
