I followed this carefully: How to start Virtual box machines automatically when booting?
It "broke" VirtualBox. I had to remove the autostart stuff and run a reconfigure command that VirtualBox recommended in the error message to get VirtualBox working again.
Created the file /etc/default/virtualbox
# virtualbox defaults file
VBOXAUTOSTART_DB=/etc/vbox
VBOXAUTOSTART_CONFIG=/etc/vbox/vbox.cfg
This is /etc/vbox/vbox.cfg:
# Default policy is to deny starting a VM, the other option is "allow".
default_policy = deny
# Create an entry for each user allowed to run autostart
USERNAME = {
allow = true
Then:
sudo chgrp vboxusers /etc/vbox
sudo chmod 1775 /etc/vbox
sudo usermod -a -G vboxusers USERNAME
It seems it is having a problem reading /etc/vbox/vbox.cfg
:~$ ls -l /etc/vbox
total 8
-rw------- 1 USERNAME USERNAME   1 Dec 14 01:37 USERNAME.start
-rw-r--r-- 1 root     root     179 Dec 14 01:31 vbox.cfg
Next:
VBoxManage setproperty autostartdbpath /etc/vbox
VBoxManage modifyvm <uuid|vmname> --autostart-enabled on
This created USERNAME.start file in /etc/vbox directory - Although the file appears to be empty.
Then the Error:
● vboxautostart-service.service
Loaded: loaded (/usr/lib/virtualbox/vboxautostart-service.sh; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2018-12-14 01:41:57 CST; 27s ago
Process: 4002 ExecStart=/usr/lib/virtualbox/vboxautostart-service.sh start (code=exited, status=2)
Dec 14 01:41:57 HOST systemd[1]: Starting vboxautostart-service.service...
Dec 14 01:41:57 HOST vboxautostart-service.sh[4002]: /usr/lib/virtualbox/vboxautostart-service.sh: 2:/etc/vbox/vbox.cfg: default_policy: not found
Dec 14 01:41:57 HOST vboxautostart-service.sh[4002]: /usr/lib/virtualbox/vboxautostart-service.sh: 4: /etc/vbox/vbox.cfg: USERNAME: not found
Dec 14 01:41:57 HOST vboxautostart-service.sh[4002]: /usr/lib/virtualbox/vboxautostart-service.sh: 5: /etc/vbox/vbox.cfg: allow: not found
Dec 14 01:41:57 HOST vboxautostart-service.sh[4002]: /usr/lib/virtualbox/vboxautostart-service.sh: 6: /etc/vbox/vbox.cfg: Syntax error: "}" unexpected
Dec 14 01:41:57 HOST systemd[1]: vboxautostart-service.service: Control process exited, code=exited status=2
Dec 14 01:41:57 HOST systemd[1]: vboxautostart-service.service: Failed with result 'exit-code'.
Dec 14 01:41:57 HOST systemd[1]: Failed to start vboxautostart-service.service.
I had this problem too. The issue is that the autostart service script is trying to include /etc/vbox/vbox.cfg just like it does with /etc/default/virtualbox. You need to use a different filename for the autostart config.
Rename /etc/vbox/vbox.cfg -> /etc/vbox/autostart.cfg
Update VBOXAUTOSTART_CONFIG in /etc/default/virtualbox:
VBOXAUTOSTART_CONFIG=/etc/vbox/autostart.cfg
