From man 5 systemd.service (section "Command Lines"):
This syntax is inspired by shell syntax, but only the meta-characters and expansions
described in the following paragraphs are understood, and the expansion of variables is
different. Specifically, redirection using "<", "<<", ">", and ">>", pipes using "|",
running programs in the background using "&", and other elements of shell syntax are not
supported.
And:
Note that shell command lines are not directly supported. If shell command lines are to be
used, they need to be passed explicitly to a shell implementation of some kind. Example:
ExecStart=/bin/sh -c 'dmesg | tac'
Wildcards are not mentioned as being supported, so you'll have to wrap that command in /bin/sh -c or /bin/bash -c like in the above example.
