I have a test web server that I'm trying to add MySQL to then further mumps. After installation of MySQL AppArmor(aa) has a parser failure and has an exit-code 123. I have purged the MySQL installation multiple times with aa returning to normal and can replicate the errors consistently.
Please help me debug this as I am eager to get this up and running.
I'm installing MySQL as root using:
# apt install mysql-*
There is an error line during installation that reads: AppArmor parser error for /etc/apparmor.d/usr.sbin.mysqld in /etc/apparmor.d/usr.sbin.mysqld at Line 9: Could not open 'Abstractions/mysql'
I reboot and aa initialization fails
# service apparmor status
AppArmor parser error for /etc/apparmor.d/usr.sbin.mysqld in /etc/apparmor.d/usr.sbin.mysqld at Line 9: Could not open 'Abstractions/mysql'again/still
As for MySQL server it looks to be up and running until... well that's another question
------Edit----- # systemctl status mysql output:
● mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2018-12-13 05:59:37 MST; 30min ago
Process: 1213 ExecStart=/usr/sbin/mysqld --daemonize --pid-file=/run/mysqld/mysqld.pid (code=exited, status=0/SUCCESS)
Process: 1049 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 1218 (mysqld)
Tasks: 29 (limit: 3517)
CGroup: /system.slice/mysql.service
└─1218 /usr/sbin/mysqld --daemonize --pid-file=/run/mysqld/mysqld.pid
Dec 13 05:59:31 web-server systemd[1]: Starting MySQL Community Server...
Dec 13 05:59:37 web-server systemd[1]: Started MySQL Community Server.
-----------Update-------------------
I created the file /etc/apparmor.d/abstractions/mysql and included the information provided by https://askubuntu.com/a/1099187/682590:
# Copyright (C) 2002-2006 Novell/SUSE
# Copyright (C) 2013 Christian Boltz
# This program is free software; you can redistribute it and/or
# modify it under the terms of version 2 of the GNU General Public
# License published by the Free Software Foundation.
/var/lib/mysql{,d}/mysql{,d}.sock rw,
/{var/,}run/mysql{,d}/mysql{,d}.sock rw,
/usr/share/{mysql,mysql-community-server,mariadb}/charsets/ r,
/usr/share/{mysql,mysql-community-server,mariadb}/charsets/*.xml r,
and so far everything is ok except that MySQL Workbench can't connect to the local database but I pretty sure that's another question. Thank you all for your help.
