25
I was trying to install Heroes of Might and Magic 3 with Play on Linux. When I start the program it gives me an error message
PlayOnLinux cannot find wine (from Wine). You should install it to use PlayOnLinux.
sudo apt-get install wine
I tried this but I got an error message:
What should I do?
$ sudo apt-get install wine
Reading package lists... Done Building dependency tree
Reading state information... Done Package wine is a virtual package provided by: winehq-staging 4.0~rc1~cosmic winehq-stable 3.0.4~cosmic winehq-devel 4.0~rc1~cosmic wine-development 3.6-1 You should explicitly select one to install. E: Package 'wine' has no installation candidate
And when I type:
$ sudo apt-get install winehq-stable
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: winehq-stable : Depends: wine-stable (= 3.0.4~cosmic) E: Unable to correct problems, you have held broken packages.
Here is my system:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:    18.04
Codename:   bionic
$ sudo apt --fix-broken install
The following packages were automatically installed and are no longer required:
    linux-headers-4.15.0-38 linux-headers-4.15.0-38-generic
    linux-image-4.15.0-38-generic linux-modules-4.15.0-38-generic
    linux-modules-extra-4.15.0-38-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo apt remove wine winehq-stable
Reading package lists... Done Building dependency tree Reading state information... Done Virtual packages like 'wine' can't be removed Package 'winehq-stable' is not installed, so not removed The following packages were automatically installed and are no longer required: linux-headers-4.15.0-38 linux-headers-4.15.0-38-generic
linux-modules-extra-4.15.0-38-generic Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo apt autoremove
state information... Done The following packages will be REMOVED:
linux-headers-4.15.0-38 linux-headers-4.15.0-38-generic linux-image-4.15.0-38-generic linux-modules-4.15.0-38-generic
linux-modules-extra-4.15.0-38-generic 0 upgraded, 0 newly installed, 5 to remove and 0 not upgraded. After this operation, 336 MB disk space
will be freed. Do you want to continue? [Y/n]  (Reading database ...
268454 files and directories currently installed.) Removing
linux-headers-4.15.0-38-generic (4.15.0-38.41) ... Removing
linux-headers-4.15.0-38 (4.15.0-38.41) ... Removing
linux-modules-extra-4.15.0-38-generic (4.15.0-38.41) ... Removing
linux-image-4.15.0-38-generic (4.15.0-38.41) ...
/etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting
/boot/initrd.img-4.15.0-38-generic
/etc/kernel/postrm.d/zz-update-grub: Generating grub configuration file ... Found linux image: /boot/vmlinuz-4.15.0-42-generic Found
initrd image: /boot/initrd.img-4.15.0-42-generic Found linux image:
/boot/vmlinuz-4.15.0-39-generic Found initrd image:
/boot/initrd.img-4.15.0-39-generic Adding boot menu entry for EFI firmware configuration done Removing linux-modules-4.15.0-38-generic
(4.15.0-38.41) ...
$ sudo apt-add-repository --remove 'deb http://dl.winehq.org/wine-builds/ubuntu/ bionic main'
Has no output.
$ sudo apt update
Get:1 http://security.ubuntu.com/ubuntu bionic-security InRelease [83.2 kB] Ign:2 https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/Ubuntu_18.10_standard ./ InRelease Get:3 http://security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [204 B] Hit:4 https://download.opensuse.org/repositories/Emulators:/Wine:/Debian /Ubuntu_18.10_standard ./ Release Get:6 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [14.5 kB] Get:7 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [9,088 B] Get:8 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [36.7 kB] Get:9 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 128x128 Icons [65.9 kB] Hit:10 http://cy.archive.ubuntu.com/ubuntu bionic InRelease Get:11 http://cy.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB] Get:12 http://cy.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB] Get:13 http://cy.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [402 kB] Get:14 http://cy.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [459 kB] Hit:15 http://deb.playonlinux.com xenial InRelease
Ign:16 http://ppa.launchpad.net/damien-moore/codeblocks-stable/ubuntu bionic InRelease Get:17 http://cy.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [245 kB] Hit:18 http://ppa.launchpad.net/deluge-team/ppa/ubuntu bionic InRelease
Hit:19 http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu bionic InRelease Hit:20 http://ppa.launchpad.net/noobslab/themes/ubuntu bionic InRelease Get:21 http://cy.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [55.7 kB] Hit:22 http://ppa.launchpad.net/rikmills/latte-dock/ubuntu bionic InRelease
Get:23 http://cy.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [105 kB] Ign:24 http://ppa.launchpad.net/vcmi/ppa/ubuntu bionic InRelease Hit:25 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
Get:26 http://cy.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 128x128 Icons [266 kB] Err:27 http://ppa.launchpad.net/damien-moore/codeblocks-stable/ubuntu bionic Release 404 Not Found [IP: 91.189.95.83 80] Err:28 http://ppa.launchpad.net/vcmi/ppa/ubuntu bionic Release
404 Not Found [IP: 91.189.95.83 80] Get:29 http://cy.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [594 kB] Get:30 http://cy.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [588 kB] Get:31 http://cy.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [199 kB] Get:32 http://cy.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [186 kB] Get:33 http://cy.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [333 kB] Get:34 http://cy.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 128x128 Icons [767 kB] Get:35 http://cy.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,464 B] Get:36 http://cy.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [5,812 B] Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/damien-moore/codeblocks-stable/ubuntu bionic Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://ppa.launchpad.net/vcmi/ppa/ubuntu bionic Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. sudo apt upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. sudo apt-get install winehq-stable Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
Edit:
$ sudo apt-add-repository https://dl.winehq.org/wine-builds/ubuntu/
Hit:1 http://deb.playonlinux.com xenial InRelease Ign:2 http://ppa.launchpad.net/damien-moore/codeblocks-stable/ubuntu bionic InRelease Hit:3 http://cy.archive.ubuntu.com/ubuntu bionic InRelease
Hit:4 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:5 http://cy.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:6 http://ppa.launchpad.net/deluge-team/ppa/ubuntu bionic InRelease Hit:7 http://cy.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:8 http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu bionic InRelease Hit:9 https://dl.winehq.org/wine-builds/ubuntu bionic InRelease Hit:10 http://ppa.launchpad.net/noobslab/themes/ubuntu bionic InRelease Hit:11 http://ppa.launchpad.net/rikmills/latte-dock/ubuntu bionic InRelease Ign:12 http://ppa.launchpad.net/vcmi/ppa/ubuntu bionic InRelease Hit:13 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease Err:14 http://ppa.launchpad.net/damien-moore/codeblocks-stable/ubuntu bionic Release 404 Not Found [IP: 91.189.95.83 80] Err:15 http://ppa.launchpad.net/vcmi/ppa/ubuntu bionic Release 404 Not Found [IP: 91.189.95.83 80] Reading package lists... Done E: The repository 'http://ppa.launchpad.net/damien-moore/codeblocks-stable/ubuntu bionic Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://ppa.launchpad.net/vcmi/ppa/ubuntu bionic Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
Pablo Bianchi
  • 17,371
sarp
  • 443
5 Answers5
41
The problem is that Wine now depends on libfaudio0, but Ubuntu versions prior to 19.10 don't include it in the standard repositories.
The link to the Winehq forum page with directions on how to install the packages is: https://forum.winehq.org/viewtopic.php?f=8&t=32192.
For Ubuntu 18.04 do:
wget https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/amd64/libfaudio0_19.07-0~bionic_amd64.deb
wget https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/i386/libfaudio0_19.07-0~bionic_i386.deb
sudo dpkg -i libfaudio0_19.07-0~bionic_amd64.deb libfaudio0_19.07-0~bionic_i386.deb
Then you should be able to update and upgrade as you would normally.
mikewhatever
  • 33,013
16
What I did:
  1. I remove all "wine" PPA using "Software and updates" tool in ubuntu / kubuntu.
  2. Then, I followed the guide here: install latest wine or here.
In my case, I added (get the codename with cat /etc/os-release)
sudo apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ xenial main'
and no other repository. Then,
sudo apt update && sudo apt install --install-recommends winehq-stable
Pablo Bianchi
  • 17,371
  1. Do
    sudo apt-add-repository --remove 'deb https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/Ubuntu_18.10_standard ./'
  2. Then
    wget -nc https://dl.winehq.org/wine-builds/Release.key
    sudo apt-key add Release.key
  3. Then
    sudo apt-get update
  4. Then install your preferred wine
    sudo apt-get install --install-recommends winehq-stable # OR
    sudo apt-get install --install-recommends winehq-devel # OR
    sudo apt-get install --install-recommends winehq-staging
Pablo Bianchi
  • 17,371
From the error you're getting, looks like you have configured the whinehq repository.
As the very same error is telling you, you have to choose which branch of wine you'd like to install, as wine is just a virtual package and it has no installation candidates so apt cannot choose by itself what to install.
As indicated here, you can install a stable version (winehq-stable), a development version (winehq-devel) or a staging version (winehq-staging).
While I'm pretty happy on my systems with winehq-staging, I suggest you install the winehq-stable branch that (as the name implies) should be the "most stable" branch of wine.
As suggested on the official WineHQ documentation, make sure to install it with the flag --install-recommends
Maybe try adding an SDL2 backport. This is especially useful to users that need to fill in dependencies that repeatedly nag you when you try to add them in. I recently found this online. The command is then followed by the package list update and then your desired choice of Wine. I tested this on Ubuntu 18.04. Specifically, Zorin OS 15. Upvote if this resolved your problem. :)
sudo apt-add-repository ppa:cybermax-dexter/sdl2-backport
sudo apt-get update
Choose one
  • sudo apt-get --install-recommends winehq-stable
  • sudo apt-get --install-recommends winehq-devel
  • sudo apt-get --install-recommends winehq-staging
Pablo Bianchi
  • 17,371
poiboi
  • 29
