Some software (Gwenview, Firefox,...) only show my system’s partition and not my data partition when I want to open a file. Only after I opened Dolphin (which lists them all), the other programs show them.
Is this a mounting problem (and how do I fix it?) or a problem inside the software? I never had this problem with previous Kubuntu-releases, only now with Kubuntu 18.04.
The sudo blkid /dev/sda2 output (for the partition I want mounted):
/dev/sda2: UUID="08CDB5494B990AD2" TYPE="ntfs" PTTYPE="dos" PARTUUID="e3611ca5-02"
The nano /etc/fstab output:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda1 during installation
UUID=e995033f-8d76-4a63-9e94-6e860aa48c60 /               ext4    errors=remount-ro 0       1
/swapfile                                 none            swap    sw              0       0
Melebius
  • 11,750
Opening an unmounted partition in a file manager like Dolphin mounts it automatically in Ubuntu. In the context menu of the partition in Dolphin, you should be able to see the Mount or Unmount option based on its current status.
If your data partition resides on the internal hard disk and should be available always, you can automount it at startup. In your specific case, you can simply add the following line to the /etc/fstab file (edit it as superuser, e.g. sudo nano /etc/fstab):
UUID=08CDB5494B990AD2   /media/data   ntfs    defaults    0   0
Add this line below the line where / is defined. It doesn’t matter whether it will go above or below the /swapfile line. The number of spaces between columns doesn’t matter, too.
The second column (/media/data) says where the partition will be mounted. This must be an existing folder which is not used for anything else. If it has not been created yet, create it using the command:
sudo mkdir /media/data
Then reboot Ubuntu and your data partition should be mounted automatically.
See also:
Melebius
  • 11,750
