I want to buy a new computer with an ASUS motherboard, and install on it Ubuntu 18.04. The hard drive will be blank with no operating system installed and not even formatted. Will I have any issues with secure boot? The firmware supports UEFI and I guess that the secure boot feature will initially be enabled.
Asked
Active
Viewed 675 times
Actually when you load optimal BIOS setting, ASUS motherboard will disable secure boot for you if there's no windows there.
Ubuntu 18.04 supports secure boot so you will not run into any problems unless you want to use unsigned drivers.
If you boot installer under efi mode, choosing simple install using entire disk, the installer will create efi partition for you and put relavant efi files into it, so you don't need to worry about anything.
Alvin Liang
- 1,753
