I'm new to Linux and I have just installed Ubuntu 18.04 having also Windows 10 as the second system and my notebook is ThinkPad T440s. When I'm on Ubuntu, I can't access Wi-Fi because it shows that there is no Wi-Fi adapter. I did some research and I think that I don't have drivers or something but I can't download anything in terminal because I was using only Wi-Fi, I'm not having wire cable with Internet. I checked what is the name of my network controller in terminal and it's Intel Corporation Wireless 7260.
Output of lshw -C network:
*-network
     description: Ethernet interface
     product: Ethernet Connection I218-LM
     vendor: Intel Corporation
     physical id:19
     bus info: pci@0000:00:19.0
     logical name: enp0s25
     version: 04
     serial: 28:d2:44:5c:c0:aa
     capacity: 1Gbit/s
     width: 32bits
     clock: 33Mhz
     capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
     configuration: autonegotlation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=0.6-3 latency=0 link=no mu
     resources: irq:43 memory:f06000000-f061ffff memory:f063e000-f063efff ioport:3080(size=32)
*-network UNCLAIMED
     description: Network controller
     product: Wireless 7260
     physical id: 0
     bus info: pci@0000:03:00.0
     version: 83
     width: 64 bits
     clock: 33Mhz
     configuration: latency=0
     resources: memory:f0400000-f0401fff
Output of sudo modprobe iwlwifi && dmesg | grep iwl:
  modprobe: ERROR: ../libkmod/libkmod.c586 kmod_search_moddep() could not open moddep file '/lib/modules/4.15.0-42-generic/modules.dep.bin'
  modprobe: ERROR: ../libkmod/libkmod.c514 lookup_builtin_file() could not open builtin file 'lib/modules/4.15.0-42-generic/modules.builtin.bin'
  modprobe: ERROR: ../libkmod/libkmod-module.c:832 kmod_module_insert_module() could not find module by name='iwlwifi'
  modprobe: ERROR: could not insert 'iwlwifi': Unkown symbol in module, or unkown parameter (see dmesg)
What can I do ?
Kulfy
  • 18,154
db14
So after installing all packets from Ubuntu I wrote this command and all drivers got downloaded
[    4.477277] iwlwifi 0000:03:00.0: loaded firmware version 17.948900127.0 op_mode iwlmvm
[    4.509779] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144
[    4.533684] iwlwifi 0000:03:00.0: base HW address: 7c:7a:91:46:43:bc
[    4.756595] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    4.758792] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
Kulfy
  • 18,154
db14
