I tried to do a chmod and delete my Pycharm logs. And somehow got in a situation that I can't boot my system.
[FAILED]Failed to start Create Volatile Files and Directories
[FAILED]Failed to start Enable support for additional executable binary        formats
[49.493137] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
[45.515265] acpi_call: Cannot get handle: Error: AE_NOT_FOUND
Opening tty1 with CTRL+ALT+F1. After entering credentials I get:
/usr/lib/ubuntu-release-upgrader/release-upgrade-motd:39
 /usr/lib/ubuntu-release-upgrader/release-upgrade-motd: cannot create /usr/lib/ubuntu-release-
upgrader/release-upgrade-available Directory nonexistent
usr/lib/update-notifier/update-motd-fsck-at-reboot: 33: usr/lib/update-notifier/update-motd-fsck-at-reboot: cannot create usr/lib/update-notifier/fsck-at-reboot: Directory nonexistent
cat: /var/lib/update-notifier/fsck-at-reboot No such file or directiory
run-parts: /etc/update-motd.d/98-fsck-at-reboot exited with return code 1
The original problem is still not solved, the same things are present, can’t boot the system. But now after reboot, there is no more error [FAILED]Failed to start Create Volatile Files and Directories, only the second one. I did many things, but I believe that this answer made difference in the first step https://askubuntu.com/a/748350/741547.
After sudo apt -f install I get:
Additional packages will be installed libgtk-3-bin.
Preparing to unpack .../libgtk-3-bin_3.18.9-1ubuntu3.3_amd64.deb ...
Adding 'diversion of /usr/sbin/update-icon-caches to /usr/sbin/update-icon-caches.gtk2 by libgtk-3-bin'
dpkg-divert: error: rename involvs overwriting 'usr/sbin/update-icon-caches.gtk2 with different file '/usr/sbin/update-icon-caches', not allowed
dpkg: error processing archive /var/cache/apt/archives/libgtk-3-bin_3.18.9-1ubuntu3.3_amd64.deb (--unpack):
subprocess new pre-installation script returned error exit status 2
Errors wew encountered while processing:
E. Sub-process /usr/bin/dpkg returned an error code (1)
After that, thing I tried to do:
sudo apt-get install libgtk-3-bin=3.18.6
E: Version '3.18.6-1ubuntu1' for 'libgtk-3-bin' was not found
Then I tried to overwrite with sudo dpkg -i --force-overwrite var/cache/apt/archives/libgtk-3-bin_3.18.9-1ubuntu3.3_amd64.deb with same error:
After that in tty1 I type systemctl status binfmt-support.service and I get:
Active: failed (Result:exit code)
Process: 1310 ExecStart=/usr/sbin/update-binfmts --enable (code=exited, status=2)
systemd[1]: Failed to start Enable support for additional executable binary formats
EDIT2:
Now im in the system with Ubuntu USB and have access to all packages. Can i somehow use ubuntu software center for repairing packages ?
waltexwq
