Alright, i've read every single thread on here regarding this topic but still don't seem to be able to find any usefull answer.
Question:
I've had win10 installed and bootable on /dev/sdc and then installed ubuntu 18.04 on /dev/sda (whole drive). Windows 10 now isn't recognized at all, disk seems fine though.
What i've tried so far:
update-grub  // only adds default stuff to grub.cfg
os-prober    // gives no output at all
what else could i try to get it to recognize win10, also windows isn't booting anymore regardless of which disk i select on F8 boot-menu (just jumps into ubuntu nonetheless.
I actually tried this over the past few days to find out that the way you install windows 10 will affect into which mode UEFI vs. legacy you can run it. You can figure out whether you may have the same problem, by switching to legacy mode in BIOS, and see if you can boot into windows for trouble shooting purpose.
What worked for me, was to remake a live USB via Rufus on another windows computer to have a UEFI install on win10.Then created an empty partition on the new windows install. Then installed Ubuntu via live USB, selecting the empty partition.
Another problem might be the drive you select to boot into during Ubuntu install. Perhaps someone can help you with the selection when you install on two separate hard drives.
