As a university student, we have to solve some problems and class activity using a Windows app called Minitab, while I don't use any other operating system except Linux.
I installed GNU Octave and statistics package, but when I searched for any tutorial or manual I failed to find out how to plot charts like P chart, Z-MR chart, XBar-S, etc. with GNU Octave. I want to know if it's possible to accomplish the same tasks with GNU Octave for statistical analysis and plotting charts?
karel
  • 122,292
  • 133
  • 301
  • 332
Mirza
  • 351
R is a system for statistical computation and graphics. It consists of a language plus a runtime environment with graphics, a debugger, access to certain system functions, and the ability to run programs stored in script files.
The core of R is an interpreted computer language which allows branching and looping as well as modular programming using functions. Additionally, several thousand extension "packages" are available from CRAN, the Comprehensive R Archive Network, many also as Debian packages, named r-cran-<name>. For R an extension (library) R Commander exists, which brings a GUI to perform most things that Minitab is capable of.
To install R and RStudio in all currently supported versions of Ubuntu open the terminal and type:
sudo apt install r-base libopenblas-base libgstreamer-plugins-base0.10-0 libgstreamer0.10-0 libjpeg62
cd ~/Downloads
wget -c --tries=3 --timeout=120 https://download1.rstudio.org/rstudio-xenial-1.1.419-amd64.deb
sudo apt install ./rstudio-xenial-1.1.379-amd64.deb
karel
  • 122,292
  • 133
  • 301
  • 332
I've also done a uni module where Octave was needed (Applied Linear Algebra) I am not familiar with minitab but I have also used MATLAB which is basically a proprietary version of Octave. Octave could do anything MATLAB could do with a slightly different syntax. I am thinking minitab may be similar along that situation in comparison. I am not sure of the level of complexity of your course...for EG very very basic in stats you can define a matrix by
 a = [0.9, 0.7;                 -define matrix
      0.1, 0.1;
      0.5, 0.4];
 b = [1; 2; 3]                  -define coefficients
This should look familiar (if not, oi vey):
For plotting charts/graphs (2-D) mostly fplot is used..e.g.
fplot (@cos, [0, 2*pi])
fplot ("[cos(x), sin(x)]", [0, 2*pi])
would define the equation the graph uses but they must be continuous.
These are all very simple expamples so you should read the Octave Manual
Hope this helps =]
