I'll paste the sequence of commands I'm trying to run to configure desktop Ubuntu 18.04 NetworkManager according to the answer in this SO question. When I perform the steps in the answer I end up with an "Error: connection verification failed".
nmcli connection show --active
NAME          UUID                                  TYPE  DEVICE
LINKSYS99999  ...                                   wifi  wlp4s0
nmcli connection edit
Valid connection types: adsl, bluetooth, bond, bridge, cdma, dummy, generic, gsm, infiniband, ip-tunnel, macsec, macvlan, 802-11-olpc-mesh (olpc-mesh), ovs-bridge, ovs-interface, ovs-port, pppoe, team, tun, vlan, vpn, vxlan, wimax, 802-3-ethernet (ethernet), 802-11-wireless (wifi), bond-slave, bridge-slave, team-slave
Enter connection type: wifi
nmcli> remove ipv4.dns
nmcli> set ipv4.ignore-auto-dns yes
nmcli> set ipv4.dns 8.8.8.8 8.8.4.4
nmcli> save
Error: connection verification failed: 802-11-wireless.ssid: property is missing You may try running 'verify fix' to fix errors.
nmcli> verify fix
Verify connection: 802-11-wireless.ssid: property is missing The error cannot be fixed automatically.
What is going on and how do I fix it? Do I need to post all my wireless details according to this SO guide?
Pablo Bianchi
  • 17,371
stackinator
  • 2,041
You have to specify a connection ID or name to change an existing connection script, or add SSID info if creating a new connection script...
man nmcli
edit {[id | uuid | path] ID | [type type] [con-name name] }
    Edit an existing connection or add a new one, using an interactive
    editor.
    The existing connection is identified by its name, UUID or D-Bus
    path. If ID is ambiguous, a keyword id, uuid, or path can be used.
    See connection show above for the description of the ID-specifying
    keywords. Not providing an ID means that a new connection will be
    added.
    The interactive editor will guide you through the connection
    editing and allow you to change connection parameters according to
    your needs by means of a simple menu-driven interface. The editor
    indicates what settings and properties can be modified and provides
    in-line help.
    Available options:
    type
        type of the new connection; valid types are the same as for
        connection add command.
    con-name
        name for the new connection. It can be changed later in the
        editor.
Post note: if this is an Ubuntu Desktop installation, it's easier to use the NetworkManager GUI to set up these settings.
Pablo Bianchi
  • 17,371
heynnema
  • 73,649
