I am new to using Ubuntu. I tried to create a Windows 10 USB boot medium with WoeUSB. I have configured a USB drive with an NTFS partition, but WoeUSB gives this error message:
Installation failed!
Exit code: 256
Log:
WoeUSB v@@WOEUSB_VERSION@@
Mounting source filesystem...
Wiping all existing partition table and filesystem signatures in /dev/sdc... wipefs:
error: /dev/sdc: probing initialization failed The command "wipefs --all
"${target_device}"" failed with exit status "1", program is prematurely aborted
Unmounting and removing "/medi/woeusb_source_1530017199_18199"...
You may now safely detach the target device
How can I proceed?
terdon
  • 104,119
The error message: error: /dev/sdc: probing initialization failed The command "wipefs --all "${target_device}"" failed with exit status "1" says that there is some minor problem (exit status 1), but it is not a serious problem. The problem in this case may be that the /dev/sdc that was selected either does not exist, you can't read or write from it, or else it has not been formatted as a filesystem that is supported by WoeUSB such as NTFS. NTFS filesystem support has been added to WoeUSB 3.0.0 and later. You can check if /dev/sdc exists in the Disks application or by running this command:
ls /dev/sdc*
karel
  • 122,292
  • 133
  • 301
  • 332
I faced the same error, and tried too many fixes until found the fix. Here is the fix in my case (I hope it works for you too):
  1. open GParted app then unmount the USB stick.
  2. open WoeUSB app and choose the .iso Windows file, and choose the USB stick. Everything goes right!
If you need to see the fix visually, I made a video on YouTube for the fix.
