I fixed the malformed line error in my sources list, and was able to run the sudo apt-get update and sudo apt-get upgrade. When I ran the update these errors came up:
W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/Release  Unable to find expected entry 'main/binary-i386/Packages' in Release file (Wrong sources.list entry or malformed file)
    W: Failed to fetch http://archive.getdeb.net/ubuntu/dists/trusty-getdeb/apps/binary-amd64/Packages  403  Forbidden
    W: Failed to fetch http://archive.getdeb.net/ubuntu/dists/trusty-getdeb/apps/binary-i386/Packages  403  Forbidden
    E: Some index files failed to download. They have been ignored, or old ones used instead.
What should I do?
Then, when I ran the upgrade, these errors showed up:
The following packages were automatically installed and are no longer required:
  account-plugin-windows-live libnvpair1 libupstart1 libuutil1 libzfs2
  libzpool2 thunderbird-locale-en thunderbird-locale-en-gb
  thunderbird-locale-en-us
Use 'apt-get autoremove' to remove them.
The following packages have been kept back:
  cups-filters cups-filters-core-drivers grub-common grub-efi-amd64
  grub-efi-amd64-bin grub-efi-amd64-signed grub2-common libldb1
  liboxideqt-qmlplugin liboxideqtcore0 liboxideqtquick0 libsmbclient
  libwbclient0 linux-headers-generic linux-headers-lowlatency
  linux-image-lowlatency linux-lowlatency linux-signed-generic
  linux-signed-image-generic openjdk-7-jre openjdk-7-jre-headless
  oxideqt-codecs-extra python-cupshelpers python-ldb python-samba qpdf samba
  samba-common samba-common-bin samba-dsdb-modules samba-libs
  samba-vfs-modules shim shim-signed smbclient system-config-printer-gnome
  ubuntu-minimal winbind
0 upgraded, 0 newly installed, 0 to remove and 38 not upgraded.
W: Duplicate sources.list entry http://dl.google.com/linux/chrome/deb/ stable/main amd64 Packages (/var/lib/apt/lists/dl.google.com_linux_chrome_deb_dists_stable_main_binary-amd64_Packages)
W: You may want to run apt-get update to correct these problems
What should I do? Thanks!
Jackie
