For CDFS, make sure menu.lst case references are UPPERCASE
I got this error when attempting to boot from a USB drive that had been set bootable, made with the Universal USB Installer. During boot, I got the Error 15 message.
I had downloaded the Ubuntu ISO image (18.04.3 LTS), and the file name was in lowercase (ubuntu-18.04.3-desktop-amd64.iso).
I used the Universal USB Installer tool to burn the image (also see caveat).
When I booted, I got the Error 15 message. With some research, it seems that the CDFS file system is case sensitive.
To remedy, I inserted the USB drive into my Windows PC, and navigated to the \boot\grub\menu.lst file, and edited it, changing all instances of:
UBUNTU-18.04.3-DESKTOP-AMD64 ➜ UBUNTU-18.04.3-DESKTOP-AMD64
UBUNTU-18.04.3-DESKTOP-AMD64.ISO ➜ UBUNTU-18.04.3-DESKTOP-AMD64.ISO
I also updated the ISO image filename in the root directory on the USB drive to be uppercase:
\UBUNTU-18.04.3-DESKTOP-AMD64.ISO
After these changes were made, I rebooted via USB, and it worked.
My final menu.lst looked like this:
# This Menu created with Universal USB Installer https://www.pendrivelinux.com
default 0
timeout 30
color NORMAL HIGHLIGHT HELPTEXT HEADING
foreground=FFFFFF
background=000000
title Boot UBUNTU-18.04.3-DESKTOP-AMD64
set ISO=/UBUNTU-18.04.3-DESKTOP-AMD64.ISO
set CASPER=/casper-rw
find --set-root %ISO%
map %ISO% (0xff)
#CLUG
map --hook
root (0xff)
kernel /casper/vmlinuz file=/preseed/ubuntu.seed noprompt boot=casper iso-scan/filename=%ISO% quiet --
initrd /casper/initrd
title Boot UBUNTU-18.04.3-DESKTOP-AMD64 acpi=off
map %ISO% (0xff)
#CLUG
map --hook
root (0xff)
kernel /casper/vmlinuz file=/preseed/ubuntu.seed noprompt boot=casper iso-scan/filename=%ISO% quiet acpi=off --
