I am at a bit of a loss. I am able to perform an nslookup and a dig on the address "imap.comcast.net" but if I try to ping it or connect to it from my application I get a "Temporary failure in name resolution". Something must be amiss in my DNS configuration but I am unsure what it is.
> ping imap.comcast.net
ping: imap.comcast.net: Temporary failure in name resolution
> systemd-resolve --status --no-pager
Global
          DNSSEC NTA: 10.in-addr.arpa
                      16.172.in-addr.arpa
                      168.192.in-addr.arpa
                      17.172.in-addr.arpa
                      18.172.in-addr.arpa
                      19.172.in-addr.arpa
                      20.172.in-addr.arpa
                      21.172.in-addr.arpa
                      22.172.in-addr.arpa
                      23.172.in-addr.arpa
                      24.172.in-addr.arpa
                      25.172.in-addr.arpa
                      26.172.in-addr.arpa
                      27.172.in-addr.arpa
                      28.172.in-addr.arpa
                      29.172.in-addr.arpa
                      30.172.in-addr.arpa
                      31.172.in-addr.arpa
                      corp
                      d.f.ip6.arpa
                      home
                      internal
                      intranet
                      lan
                      local
                      private
                      test
Link 2 (ens3)
      Current Scopes: DNS
       LLMNR setting: yes
MulticastDNS setting: no
      DNSSEC setting: no
    DNSSEC supported: no
         DNS Servers: 10.0.0.2
          DNS Domain: ec2.internal
> cat /etc/resolv.conf
# This file is managed by man:systemd-resolved(8). Do not edit.
# This is a dynamic resolv.conf file for connecting local clients to the
# internal DNS stub resolver of systemd-resolved. This file lists all
# configured search domains.
# Run "systemd-resolve --status" to see details about the uplink DNS servers
# currently in use.
# Third party programs must not access this file directly, but only through the
# symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a different way,
# replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 127.0.0.53
search ec2.internal
Some more forensic information /etc/resolv.conf is a symlink as seen here
> readlink -f /etc/resolv.conf
/run/systemd/resolve/stub-resolv.conf
If I change the symlink and restart systemd.resolve I can ping the address but it appears to disable dns caching
>sudo service systemd-resolved stop
>sudo rm -f /etc/resolv.conf
>sudo ln -s /run/systemd/resolve/resolv.conf /etc/resolv.conf
>sudo service systemd-resolved start
>sudo systemd-resolve --statistics
DNSSEC supported by current servers: no
Transactions
Current Transactions: 0
  Total Transactions: 0
Cache
  Current Cache Size: 0
          Cache Hits: 0
        Cache Misses: 0
DNSSEC Verdicts
              Secure: 0
            Insecure: 0
               Bogus: 0
       Indeterminate: 0
I think I had this issue before. I used the first answer in this question to resolve it: Wrong nameserver set by resolvconf and NetworkManager
The answer is to change the resolv.conf symlink:
reboot
For me the answer was that the DNS entries were missing in my Netpan setup. I edited them manually (in my case /etc/netplan/50-cloud-init.yaml but I realize that this might be specific to my environment, and might not "stick").
I changed
network:
ethernets:
    ens160:
        addresses:
        - 10.8.25.116/28
        dhcp4: false
        gateway4: 10.8.25.113
        nameservers:
            addresses: []
            search: []
version: 2
to
network:
ethernets:
    ens160:
        addresses:
        - 10.8.25.116/28
        dhcp4: false
        nameservers:
            addresses: [8.8.8.8,4.2.2.2]
            search: []
version: 2
and then applied it using
netplan apply
ISparkes
  • 151
It may seem crazy ... But after a LONG study of the logs, similar situations on the Internet ... It is banal for me helped - updating the packages!
Specifically, these commands:
systemctl disable systemd-resolved
systemctl stop systemd-resolved
reboot
apt update && apt upgrade
reboot
systemctl enable systemd-resolved
systemctl start systemd-resolved
In particular, I think the systemd package was somehow corrupted ...
PS: Do not try to solve the problem with your forehead right away! Update / reinstall packages first! Save your time ;-)
Denik
I just had this issue and it drove me bananas. I checked the DNS and all the local host networking. it was all perfect. There were NO misconfigurations in the host networking: comparative analysis of other hosts which had the same config were working, but this host wasn't. Why?!?!?
The answer was a duff NAT rule in the Internet GW.
<facepalm>The DNS error message was a SYMPTOM of the problem, not the actual problem itself.</facepalm>
A quick check for missing or incorrect NAT rules in your Internet GW could save you a lot of wasted time...
F1Linux
  • 1,256
