So I've been working on creating a custom Ubuntu 16.04.5 image. I follow the instructions here to chroot into the file system that gets put onto the computers and do apt update && apt full-upgrade. After that I package everything up into an ISO and use that to image a computer. I do most of my testing in VirtualBox & when I tell the VM to boot using UEFI, the Ubuntu installation gives me an error:
The 'grub-efi-amd64-signed' package failed to install into /target/.
Without the GRUB boot loader, the installed system will not boot.
So I went back to the chroot environment, installed the 'grub-efi-amd64-signed' package (there's no internet connection during the install process), and all is well. This was working fine for me until recently. Now, after the installation I'm now taken to the Grub command prompt.
Now it seems there's an update to Grub2; from 2.02~beta2-36ubuntu3.18 to 3.19. If I don't install that update I can't use UEFI because of that error I get. If I install the 'grub-efi-amd64-signed' then if forces the other Grub packages to update. If I DO install that package & all the updates, then the computer boots to the Grub command prompt. I really don't know where to begin to fix this. What can I do to update Grub & fix the issue?
Could this be because the ISO is using the previous version of Grub?
EDIT: Something else I've noticed. I'm able to get everything to install (and boot) correctly if I apt-mark hold on the following packages:
linux-generic-hwe-16.04
linux-image-generic-hwe-16.04
linux-headers-generic-hwe-16.04
linux-signed-generic-hwe-16.04
grub-common
grub2-common
After that, I can apt full-upgrade, create the ISO & do the install... So why does it break when I update the kernel & Grub?
FWIW, here's my preseed file:
### Localization
d-i debian-installer/locale string en_US
d-i console-setup/ask_detect boolean false
d-i console-setup/layoutcode string us
### Network Configuration
d-i netcfg/dhcp_timeout string 300
d-i netcfg/dhcp_failed note
d-i netcfg/dhcp_options select Do not configure the network at this time
d-i netcfg/get_hostname string dev
d-i netcfg/get_domain string example.com
### Account Setup
d-i passwd/user-fullname string User
d-i passwd/username string user
d-i passwd/user-password-crypted password $6$...
d-i user-setup/allow-password-weak boolean true
d-i user-setup/encrypt-home boolean false
### Clock and Time Zone Setup
d-i clock-setup/utc boolean true
d-i time/zone string US/Eastern
d-i clock-setup/ntp boolean true
### Partitioning and Encryption
# Use LVM for encryption
d-i partman-auto/method string crypto
# Suppress LVM and RAID warnings about previous configurations
d-i partman-lvm/device_remove_lvm boolean true
d-i partman-md/device_remove_md boolean true
# Confirm writing on existing partitions
d-i partman-lvm/confirm boolean true
# Use the entire logical volume
d-i partman-auto-lvm/guided_size string max
# Have all files on this partition only
d-i partman-auto/choose_recipe select atomic
# Specify ext4 since the default is ext3
d-i partman/default_filesystem string ext4
# Begin the partitioning without user interaction
d-i partman-partitioning/confirm_write_new_label boolean true
d-i partman/choose_partition select finish
d-i partman/confirm boolean true
d-i partman/confirm_nooverwrite boolean true
# Use the encryption key to perform the encryption
partman-crypto partman-crypto/passphrase string password
partman-crypto partman-crypto/passphrase-again string password
# Agree to use weak passphrase and confirm if prompted
partman-crypto partman-crypto/weak_passphrase boolean true
partman-crypto partman-crypto/confirm boolean true
### Package Selection
tasksel tasksel/first multiselect standard
tasksel tasksel/first multiselect ubuntu-desktop
d-i pkgsel/updatedb boolean false
### Boot Loader Installation
d-i grub-installer/only_debian boolean true
### Finishing Up the Installation
ubiquity ubiquity/reboot boolean true
