I've run into a problem with Wine/winetricks, where I get the following error:
Wine cannot find the ncurses library (libncurses.so.6).
However, running sudo apt install libncurses6 just gives me a notification that the package is already installed
Running 18.10
hiigaran
  • 6,843
Wine may need 32-bit library.
You can install it with
sudo apt-get install libncurses5:i386 libncurses6:i386
and then retry.
N0rbert
  • 103,263
Run these commands Below:
Wine may need a 32 bit library You can install it with :
sudo apt-get install libncurses6:i386
and then try :
That should work..
Output terminal
Ibster
  • 402
Below command fixed it for me if nothing above helps.
sudo apt-get install libncurses5-dev libncursesw5-dev
Jegan
