I'm having trouble installing wine from terminal. I used sudo apt-get install wine-stable and sudo apt-get install wine-stable-i386 and received this error.
Reading package lists... Done
Building dependency tree
 wine-stable-i386:i386 : Depends: libc6:i386 (>= 2.28) but 2.27-3ubuntu1 is to be installed
                         Recommends: libcapi20-3:i386 but it is not going to be installed
                         Recommends: libcups2:i386 but it is not going to be installed
                         Recommends: libglu1-mesa:i386 but it is not going to be installed or
                                     libglu1:i386
                         Recommends: libgsm1:i386 but it is not going to be installed
                         Recommends: libgssapi-krb5-2:i386 but it is not going to be installed
                         Recommends: libkrb5-3:i386 but it is not going to be installed
                         Recommends: libodbc1:i386 but it is not going to be installed
                         Recommends: libosmesa6:i386 but it is not going to be installed
                         Recommends: libsane:i386 or
                                     libsane1:i386 but it is not going to be installed
                         Recommends: libv4l-0:i386 but it is not going to be installed
                         Recommends: libxcomposite1:i386 but it is not going to be installed
                         Recommends: libxslt1.1:i386 but it is not going to be installed
Any recommendations?
Thomas
  • 6,433
