One solution was using KDE, I installed the packages for the desktop environment and built a simple xstartups file which just initiates the desktop.
Instructions:
Somewhat based, on https://wiki.centos.org/HowTos/VNC-Server
Here are the libraries, from a fresh install of Ubuntu 18.04:
sudo apt-get install build-essential openssh-server tightvncserver kubuntu-desktop xfonts-75dpi xfonts-100dpi
After the install and a reboot. Login and navigate to the base directory. cd ~, run tightvncserver :1 command and initialize the configuration.
Now run tightvncserver -kill :1 to shutdown the vnc server.
Let's make the config changes.
Run sudo rm -rf .vnc/xstartup && touch .vnc/xstartup && sudo chmod +x .vnc/xstartup to delete the file, and recreate it with the correct file properties.
Ok, now jump into the editor and make a couple edits. sudo nano .vnc/xstartup
Enter this as the file contents:
#!/bin/sh
# Config
unset DBUS_SESSION_BUS_ADDRESS
# Settings
export XKL_XMODMAP_DISABLE=1
export XKB_DEFAULT_RULES=base
export QT_XKB_CONFIG_ROOT=/usr/share/X11/xkb
# Locale
export LANG=en_US.UTF-8
export LANGUAGE=
export LC_CTYPE="en_US.UTF-8"
export LC_NUMERIC="en_US.UTF-8"
export LC_TIME="en_US.UTF-8"
export LC_COLLATE="en_US.UTF-8"
export LC_MONETARY="en_US.UTF-8"
export LC_MESSAGES="en_US.UTF-8"
export LC_PAPER="en_US.UTF-8"
export LC_NAME="en_US.UTF-8"
export LC_ADDRESS="en_US.UTF-8"
export LC_TELEPHONE="en_US.UTF-8"
export LC_MEASUREMENT="en_US.UTF-8"
export LC_IDENTIFICATION="en_US.UTF-8"
export LC_ALL=
# Uncomment the following two lines for normal desktop:
# unset SESSION_MANAGER
# exec /etc/X11/xinit/xinitrc
[ -x /etc/vnc/xstartup ] && exec /etc/vnc/xstartup
[ -r $HOME/.Xresources ] && xrdb $HOME/.Xresources
xsetroot -solid grey
plasmashell &
startx
type <Ctrl + x> for the menu and type y to save and hit Enter to exit.
One more, touch ~/.xinitxc && sudo nano ~/.xinitrc to create a basic X Server Initialization profile.
Add this line to the file:
startkde
Now save whatever your output to hostname is, then in some client computer with interfacing access to the computer where all of this was configured in.
Download a vnc viewer, I prefer RealVNC viewer. I am not associated with the company, in any way.
https://www.realvnc.com/en/connecan/download/viewer/
While that is downloading, open a ssh connection to the computer. Follow this guide.
https://www.digitalocean.com/community/tutorials/how-to-configure-ssh-key-based-authentication-on-a-linux-server
While logged in to the shell on the remote computer.
Start the vncserver as before with tightvncserver -compatiblekbd :1
Leave that open.
Enter in to the login bar in that client computer, in the RealVNC, the hostname output. Like so:
hostnamehere:1 (<= hostnamehere is the output) and connect. Login with your regular user and enjoy.
I was really looking to have this setup type but with the Official Ubuntu Gnome Desktop
